Old 08-07-2009, 03:29 AM   #1
toolbelt Tina's Avatar
how many teeth
I am installing 3/4 red oak.
I need a new saw blade. How many teeth should it have?
Can I swap my table saw with my miter saw blade?
thanks Tina
toolbelt Tina is offline   Reply With Quote
Old 08-07-2009, 07:06 AM   #2
how many teeth
Not that big of an issue really for installing wood floors. You're cuts will be covered up by trim, right? Even a 32 tooth general purpose blade will cut sufficient if you don't rush the cut. If it's going to show, bring the saw blade into the wood slow, not fast & you'll get a clean enough cut.
pinwheel45 is offline   Reply With Quote
Old 08-07-2009, 07:07 AM   #3
how many teeth
If you are ripping on the table saw, that takes a blade designed for ripping. Miters generally need a blade designed for crosscutting. Those blades are different. More teeth generally means a smoother cut.
Old 08-07-2009, 01:38 PM   #4
how many teeth
thanks guys for your input.
I thought about the trim covering up the ends. I was just wondering if my blade is dull then I thought it might chew it up beyond what the trim would extend over.
The other area I was worried about was the door way.
thanks again
Miter Saw Blades \ Crown Moulding Jigs Discussion WorkOnIt Carpentry 3 06-17-2007 05:50 AM
