-   -   how many teeth (http://www.diychatroom.com/f5/how-many-teeth-50415/)
toolbelt Tina 08-07-2009 03:29 AM
how many teeth
I am installing 3/4 red oak.
I need a new saw blade. How many teeth should it have?
Can I swap my table saw with my miter saw blade?
thanks Tina
pinwheel45 08-07-2009 07:06 AM
Not that big of an issue really for installing wood floors. You're cuts will be covered up by trim, right? Even a 32 tooth general purpose blade will cut sufficient if you don't rush the cut. If it's going to show, bring the saw blade into the wood slow, not fast & you'll get a clean enough cut.
Just Bill 08-07-2009 07:07 AM
If you are ripping on the table saw, that takes a blade designed for ripping. Miters generally need a blade designed for crosscutting. Those blades are different. More teeth generally means a smoother cut.
toolbelt Tina 08-07-2009 01:38 PM
thanks
thanks guys for your input.
I thought about the trim covering up the ends. I was just wondering if my blade is dull then I thought it might chew it up beyond what the trim would extend over.
The other area I was worried about was the door way.
thanks again
