Old 11-29-2011, 11:19 PM   #1
How to make a custom floor transition
I have laid new travertine in my kitchen and it butts up against the hardwood floor in the other parts of the house. The kitchen flooring is now 1 1/4" higher than the hardwood floor. I've checked a lot of places and it seems 3/4" or smaller is the standard size for transitions and reducers. So, my question is, do i have to make my own or is there a product out there that could work for me? If I have to make my own, does anyone have some tips on what to use and how to make it? I would imagine I need to find a 2x2 or something, but it needs to be nice, and not rough stock, and then cut it at a 45 degree angle to make a ramp? I need some advice, I'm running into lots of roadblocks and don't know what to do. Thanks!
chuckp27 is offline   Reply With Quote
Old 11-30-2011, 06:37 AM   #2
Man of many hats
wrangler's Avatar
If you have a table saw or access to one you can mill a piece of hardwood, I would suggest oak for strength, to any dimension you want. The big box stores can sell you a piece of 2x2 oak that would work. Of course 2x2 will actually be 1 1/2 x 1 1/2 so you will first need to set your saw blade to 1 1/4" wide. Run your block through, turn it 90 degrees amd run it again, and you now have a piece 1 1/4 x 1 1/4. Depending on your where your transition meets the other floor you might not need to do the second cut and leave it at 1 1/2 x 1 1/4. Then you can set the blade to 45 degrees to ease the edge. I would not cut the 45 the entire depth (from 1 1/4 down to 0) but so that it only takes off 3/4 x 3/4, leaving 1/2" at both the hardwood floor and where it meets the tile to prevent chipping or breaking. Sand, stain and nail it down!
Man of many hats
wrangler is offline   Reply With Quote
Old 11-30-2011, 12:46 PM   #3
I can't seem to find anything nice that's a 2x2 or 4x4 that I could cut down at the local home depot or lowes. Am I missing it, or is there another store that would have some nice oak this size? That's part of my problem; I can't seem to find any good stock that I could use.
Old 11-30-2011, 01:06 PM   #4
41 years in construction
Lowes
2x2x3 oak (1.5" x 1.5" x 36")
item 8338
model 08835
Arkitexas is offline   Reply With Quote
Old 11-30-2011, 04:40 PM   #5
Man of many hats
wrangler's Avatar
Its with the project wood, near the other oal and clear pine
Man of many hats
Old 11-30-2011, 04:50 PM   #6
Tileguy
Bud Cline's Avatar
Maybe you should give this a little more thought. If you are going to cut a piece at a 45 degree angle for a transition you just as well not waste your money and time. Forty-five degrees would be every bit the tripper that having nothing there would be.
A piece of stock 2" X 2" also isn't the thing to do. You are trying to abbreviate this thing too much. Typically transitions of this height would be about four inches wide in my experience. Only the low cost floating floors use transitions that are only around two inches.
A wider piece would give you a softer slope opportunity.
You can buy five-quarter oak in different widths and make whatever you want.
Old 11-30-2011, 05:25 PM   #7
i agree with bud.. carry it out 3-4" to make a smoother transition..
What have I done is offline   Reply With Quote
Old 12-02-2011, 12:16 AM   #8
Originally Posted by Arkitexas View Post
Lowes
item 8338
model 08835
i did find this, thanks. i wish it were longer, in my case, i'm going to have to use a couple next to each other and i'm not thrilled about the seam. i'm going to try a test one this weekend.
Old 12-02-2011, 12:18 AM   #9
Thanks, good thoughts. What do you have in mind, could you point me to the right wood at lowes or home depot online, like the one referenced above? That helped me a lot. Thanks!
Old 12-02-2011, 11:48 AM   #10
Tileguy
Bud Cline's Avatar
You just may have to buck up and tighten your belt, expand your thinking, and open your wallet and do something you have never done before, it will be a life-changing experience for you I know but some of life's traumas just can't always be avoided...
You may have to visit a real lumber yard.
best way to make a small water tank? Red Squirrel Plumbing 22 05-01-2011 07:12 AM
New custom house, concerns/problems. pretzels Building & Construction 15 04-16-2011 02:17 PM
Best way to make a roof exit or door? swaff Roofing 5 10-22-2010 02:15 PM
Best way to make 45 degree mitre jig BobS0327 Carpentry 7 09-22-2010 12:53 AM
how to make waterfall with fake rocks ponch37300 Landscaping & Lawn Care 11 05-22-2009 02:04 PM
