How Long Between Tiling Steps? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-12-2010, 05:07 PM   #1
How long between tiling steps?
What do you pro's or semi pro's recommend for time between steps in the tiling process? I have my mortar bed in the shower completed and will lay the tile tomorrow.
How long for the thinset to dry/cure before grouting?
How long for the grout to dry before sealing?
How long before the shower should be used?
I'm sure the materials have some recommendations printed on them which I haven't read yet....just looking for some real world numbers.
ptraz is offline   Reply With Quote
Old 03-12-2010, 05:33 PM   #2
DIY staff
Rewards Points: 7,174
You can grout the next day. Are your walls done already? I don't grout the floor till the walls are done.
Why work on top of a freshly grouted floor.
In a shower I use epoxy grout--no sealing is required.
same epoxy goes on the walls and floor--all gets done at the same time,--Mike---
Old 03-12-2010, 06:38 PM   #3
I do have one row of wall tile to do and the floor. I wil do the wall tile first. This was a redo of a shower pan that was done completely wrong by someone else.
Old 03-12-2010, 07:01 PM   #4
DIY staff
I remember the post---How did the mud pan work for you? I've done a bunch over the years.
They still make me nervous. Never had a problem--but it is a pain trying to get the pitch even.
The one I did last week was the best so far--I dragged a cement mixer to the job--the deck mud had a perfect consistency.I may make that a standard practice.
If you use cement grout--wait a week or two to seal it. I have little faith in sealers,I believe that they are more of a "feel good"thing than a real useful product.
If you can talk these folks into spending the money--Spectralock epoxy is a good product.
Figure about $100.00 it do a tiled shower.
EDIT--for just the pan and one row of tile--a $25.00small unit will do.
Old 03-12-2010, 08:13 PM   #5
The mud pan worked out well. It appears to be pretty uniform and sloped properly. The curb was the scary part but also turned out pretty good I think for my first one. I'll get some pics tomorrow before the tile goes on.
The Following User Says Thank You to ptraz For This Useful Post:
oh'mike (03-12-2010)
Why long lasting bulbs go out of service quickly? art2670 Electrical 8 10-27-2009 09:10 AM
steps up from concrete patio annrose Landscaping & Lawn Care 2 09-10-2009 08:07 PM
Tiling a large and long area pberger Flooring 1 09-07-2009 10:09 PM
Swift Lock laminate wood flooring on steps? Leche4evr Flooring 1 08-29-2009 01:49 PM
Wooden steps (7 risers) up to front porch chrissygarden Building & Construction 1 08-18-2009 01:48 PM
