How To Level Old Shower Bed? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-16-2013, 11:08 PM   #1
Rewards Points: 31
How to level old shower bed?
I want to tile over the slab area where a previous shower had been.
It's about 2'x3' and dips about 2" below level at center (drain). The slab is continuous (no separate shower pan).
I was thinking mortar to level the depression, but I'm afraid the mortar won't bond where it feathers to 0 at the edges. I read that 2" is too thick for self-leveling compound.
Any advice? Thanks!
Queso Bandit is offline   Reply With Quote
Old 04-17-2013, 05:58 AM   #2
DIY staff
Rewards Points: 7,174
Deck mud ,set in a bed of wet thinset will fill the deeper parts---self leveling compound or Ardex Feather Finish for the thin spots----
Old 04-17-2013, 06:23 AM   #3
Rewards Points: 13,694
You are going to plug that drain off first, right?
oh'mike (04-17-2013)
Old 04-17-2013, 07:19 AM   #4
Amateuralex's Avatar
Rewards Points: 270
2" is too thick for SLC in a single coat, but you can do multiple coats if you prime in between. It's rather easy to work with IMHO.
Amateuralex is offline   Reply With Quote
Old 04-17-2013, 10:54 AM   #5
Rewards Points: 31
Thanks!
I'll plan on scraping off the existing paint, use some deck mud on thinset and finish the last 1/4 inch with leveling compound.
After I plug the drain
The Following User Says Thank You to Queso Bandit For This Useful Post:
Tags
level a floor
Shower Curb erose54 Concrete, Stone & Masonry 3 05-20-2012 05:11 AM
beginner's question about shower fixtures diy'er on LI Plumbing 6 02-19-2012 10:05 PM
Shower Rough In - Miscellaneous Questions tev9999 Plumbing 1 02-13-2012 09:40 PM
Failed shower pan in old tiled shower tmpyankee Plumbing 3 07-14-2010 06:43 AM
shock in shower tbwoods Electrical 64 07-23-2009 11:26 AM
