How To Level/fix Subfloor Before Hardwoods? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-16-2013, 07:35 PM   #1
Rewards Points: 384
How to level/fix subfloor before hardwoods?
After ripping up the underlayment the subfloor has some chunks taken out. I'd rather not rip it up considering the granite that's on the counters and it's under all of the counters. I plan on sanding it to remove splinters but how should I go about leveling fixing the holes? I heard that self leveling stuff is hard to work with.
How to level/fix subfloor before hardwoods?-2013-06-16-19.28.43.jpg
RyanD is offline   Reply With Quote
Old 06-16-2013, 08:29 PM   #2
Rewards Points: 13,274
Is it out of level or not flat?
If it's flat do not worry about those bad spots, just go over the whole thing with 3/8 A/C underlayment plywood.
Then 1/4 tile board set in a bed of thinset.
Are you sure this floor will even support tile? What's the free spans, spacing and width of the floor joist?
Old 06-16-2013, 08:45 PM   #3
Rewards Points: 384
Ah, I should've mentioned I'm removing the underlayment so it's level with the other hardwood. I'm going to be putting 5" hardwood floor over this so I'm worried about the holes.
Old 06-16-2013, 09:15 PM   #4
DIY staff
Rewards Points: 7,174
Hardwood will easily ride right over missing chunks---Unless you have large areas with entire plys missing you should be fine----
Installing hardwoods, cant locate studs GlennM515 Flooring 6 06-29-2011 08:40 PM
Old homes - Hardwoods everywhere??? Clemsig07 Flooring 1 06-15-2011 09:41 AM
Thoughts on Kahrs Spirit / Award Hardwoods seventyfour Flooring 0 05-23-2011 04:27 PM
salvaging the floors under glued down hardwoods christymichael General DIY Discussions 5 03-07-2011 08:31 AM
Can I put hardwoods on top of existing travertine? jmwinke Flooring 11 11-22-2009 02:33 AM
