We're upgrading a cabin and decided to put in pine flooring to match the original flooring. Problem is that there is a dip in the floor. Joists are 2' on center, and there is a drop of about 1/4" to 1/2" between two of the joists. We plan on running the flooring perpendicular to the joists. So my question is, how level does the floor have to be? What problems might I have if I run the flooring over this?
Just an idea. If the dip is just between joists in a non-load bearing area and somewhere midspan try streching a string tightly across the subfloor in a spiderweb fashion about every 30 degrees with the center of the web at roughly the deepest point. Then use a little 1/4 in. masonite, a little 1/8 in. masonite, and a little 1/16 in. veneer and brad nail or staple pieces down to roughly fill in the pocket space up to the spiderweb. It doesn't have to be perfect if you are using 2 1/4 T&G, or 4, 6, 8, & 10 in. rough sawn boards. The problem, though, may be a cracked, split, termite infested, or warped joist or timber under the floor so some investigation would be prudent.
Thanks for the input. I was hoping to hear someone say it doesn't have to be perfect. I wish I had noticed the problem before I had put down the subfloor and built the walls....would have been an easy (or at least much easier) problem to fix.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
