How To Lay Floor On A Wall? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-22-2010, 11:20 PM   #1
Question
How to lay floor on a wall?
Hello all, I am a new member looking for some thoughts on my options.
I am looking to lay an engineered bamboo hardwood (T&G) around the front and side of my bar. I have a 3/4" construction grade plywood base. I am thinking of use a construction adhesive (PL Premium) to attach the flooring to the plywood. I want to use this as a brad nailer will leave a mess of holes and I have been told a flooring nailer won't work properly as it is being held against a wall instead of a floor.
So, two questions...
1. If you wouldn't do it this way, how would you do it?
2. Should I attach the floor horizontally or vertically across the bar
Batesy is offline   Reply With Quote
Old 09-23-2010, 09:55 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 290
Why not nail into the tongue with that nailer? I'd install them vertical or diagonally, never horizontally.
Jaz
Old 09-23-2010, 11:49 PM   #3
I just figure with it being a bar front people will be bumping it with knees and feet constantly and thin brad nails won't give much support.
Why would you not go horizontally?
Cutting through masonry wall mwpiper Remodeling 4 04-17-2010 11:30 AM
building a wall against an exterior wall Mike L General DIY Discussions 2 08-20-2009 03:50 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 04:29 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
