How To Lay Ceramic Tile On A Concrete Slab? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-16-2009, 06:33 PM   #1
Question
How to lay ceramic tile on a concrete slab?
I need help? I am trying to lay tile
I have never did tile before. I have a few basic questions.
1) After i snap my line I'll end up with a 10" cut on both sides of my room but if I move the tile all the way flush against one wall it will be centered on the door and I'll have a 4" cut on the opposing wall is that the proper way to do it or what?
2) At what point do you put down something for cracks in the slab, I mean what size cracks are not acceptable before you have to repair them?
3) Also if there is some flat paint over spray on the floor does it need to be ground down or just mopped?
4) By the back sliders the concrete slab is about 1" above the slider door track any suggestions?
5) how do you transition from tile to carpet?
Any help would be greatly appreciated.
Thank You
Fishnzone is offline   Reply With Quote
Old 08-16-2009, 07:49 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
1.) There is no "proper way", do what you think looks best.
2.) Any existing cracks are a threat to a tile installation.
3.) Paint is a known bondbreaker and should be removed.
4.) None!
5.) Some use a metal or plastic tile edging some use nothing.
XXX
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 06:12 PM
Cork or engineered wood over concrete slab w/ Radiant heat, HELP! newdyier Flooring 9 11-04-2008 04:11 PM
Concrete prep: how to remove old adhesive/grout etc from ceramic tile? Matt Devo Flooring 5 10-01-2008 08:53 PM
Joining carpet and ceramic tile rooms TedT Flooring 10 05-21-2008 08:25 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
