-   -   How to keep tile floor level with laminate? (http://www.diychatroom.com/f5/how-keep-tile-floor-level-laminate-154800/)
farang 08-25-2012 10:54 AM
I am redoing the floor in my living room / kitchen with laminate wood.
My foundation is just a slab on grade with 2x4" sleeper joists and then 3/4" plywood T&G subfloor, on which I will lay an underpad for the laminate wood floor and then the wood floor itself.
In front of my main entry door in that same room I want to do tile. I am planning on doing a simple 3'x5' area so I can use a single sheet of Backerboard.
How do I keep the finished top level of the tile flush with the top level of the wood? The backerboard is 1/2" and the tiles are 10.5mm thick. Add in the two layers of thinset and I am about 3/4" above the level of the laminate wood floor.
I was thinking I could cut away the 2"x4" sleeper joists in this 5'x3' area, and instead use 1"x4" which will give me the 3/4" back.
Is this the right way to go about this?
joecaption 08-25-2012 11:07 AM
1/4 tile board is used on floors not 1/2"
DannyT 08-25-2012 11:16 AM
is that 3/4 plywood subfloor or boards 4-6 inches wide?
farang 08-25-2012 11:34 AM
3/4" plywood
DannyT 08-25-2012 12:19 PM
when i tiled my kitchen i was butting up to 3/4 inch hardwood and i used ditra under the tile and it came out within a 1/16 of an inch level with the hardwood. the ditra is 1/8 thick and they also make one 5/16 thick i believe if you need a little more height. which one you use would depend on how thick your laminate is. here is the link to the ditra. you would not need the cement board if you use the ditra. the ditra gets attatched with thinset the same as the tile.
http://www.schluter.com/2080.aspx
Duckweather 08-25-2012 01:41 PM
I don't think 1/4" will support the tile without cracks. Best would be cut out tile area replace 2x sleepers with 3/4" pt boards and 3/4" plywood gives you back the 3/4" and standard installation.
JetSwet 08-25-2012 02:47 PM
Cement board is not for support but for bond/ filler, your support is the plywood which shouldn't be PT inside the home nor only 3/4" ya need more ply since there only sleepers 16" apart.
farang 08-25-2012 04:43 PM
Thanks for the info.
I already have the sheet of backerboard in 1/2" so I think I will just make it work instead of driving 45 minutes to the store.
oh'mike 08-25-2012 04:59 PM
Your choice----45 minutes is a long time to achieve a level surface
farang 08-25-2012 05:35 PM
It will still be level
