How To Install Tiles On Plywood? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-18-2008, 08:49 PM   #1
how to install tiles on plywood?
I want to install tiles in my kitchen.
I removed the old tiles. But what do i use to install the new tiles?
What products (HD names) to do i need?
I was advised to (cheaper way):
-staple down wire mesh to the subfloor
-poar thinset and Let it dry and
-then use mortar to apply tiles
and/or
-prepare a mud bed
-install tiles with mortar
correct?
Boca is offline   Reply With Quote
Old 01-18-2008, 09:17 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 412
A true mortar-mud job would be great, but it's not exactly something a novice is going to be able to do. The first method you described a called a scratch-coat, and it's JUNK!
You should be thinking to either use a CBU, (Cementitious Backer Unit), an uncoupling membrane such as Ditra or hire someone that is a licensed tilesetter. Where are you located?
Jaz
Old 01-18-2008, 10:02 PM   #3
Building and plumbing
USP45's Avatar
Rewards Points: 150
Jaz
Ditto and double ditto. First off the thinset adds weight to the floor between the joists without support. Using a cementiciouse board laid 90 degrees to the joists will add support. If you do thinset, you get cracked joints, if you use cement board, nice looking and lasting job
USP45 is offline   Reply With Quote
Old 01-18-2008, 11:21 PM   #4
So you recommend using cement board for the flooring?
And would you screwed into the sub floor or into the joist?
I prolly wouldn't do it myself, but if a tile guy came by i want to be informed.
Old 01-19-2008, 09:23 AM   #5
You lay the CBU (cement board) in acrylic modified thinset, and then nail or screw down the CBU according to the nail pattern printed on the board (it's like every 12 inches or something). Tape and fill the joints with thinset and alkali resistant fiberglass tape. Then when it dries lay the tile over that with regular thinset (not modified).
NateHanson is offline   Reply With Quote
Old 01-20-2008, 03:10 AM   #6
God bless cement board.
Old 01-20-2008, 11:58 AM   #7
Tileguy
JazMan's Avatar
Rewards Points: 412
Hi all,
It's the other way around on the thinsets. The thinset to install the CBU varies by manufacturer, but you can get away with unmodified. However you need to use modified thinset to install the tiles over all cement backer boards.
Jaz
Old 01-22-2008, 07:08 PM   #8
electrician / handyman
outdoor
can this method be used outside
sethc is offline   Reply With Quote
DIY Chair mat from plywood and carpet tiles jbwaechter Flooring 3 08-20-2009 06:29 AM
How do you Lay Large Tiles over Plywood Subfloor? 1655graff Flooring 20 10-01-2007 05:28 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 07:43 PM
Vinyl Tiles over pre-existing layers Thwiipp Flooring 1 09-05-2006 01:10 PM
