Old 07-19-2012, 12:51 AM   #1
Post
How to Install Semi Solid Oak Flooring
It is essential to measure the room’s dimensions to determine how much flooring will be required to finish the project.
1 – Purchase semi solid flooring Dublin from a home improvement store and take it inside your home.
2 – Apart 1/2 –inch from room’s wall, make a mark on the floor with the help of pencil.
3 - Set the first piece in place along the wall and secure it with the nail gun. Place the nail into the tongue of the oak flooring. Measure a piece of wood flooring and cut it to the required length with the circular saw.
4 - Fall the cut piece into place. Insert a pull bar over the end of the piece of flooring and pull it towards the first piece. Secure the flooring with the nail gun.
5 - Set the other half of the cut piece in place for the second row. Set a block of wood in front of the piece of flooring and tap on it with the hammer. This will align the pieces of flooring together.
6 - Secure it with the nail gun and then install flooring in the same way as the first row to install the next row.
7 - Repeat the installation steps to finish flooring in the room.
jastin123 is offline   Reply With Quote
Tags
semi solid oak flooring, semi solid wood flooring
Hardwood Flooring install around this trim? Cmudr1 Flooring 4 01-31-2013 11:29 PM
subfloor and solid hardwood or engineered flooring? help me decide. amh56 Flooring 9 06-04-2012 07:33 PM
Labor costs to install laminate/tear out old flooring awalker1015 Off Topic 7 07-27-2010 05:44 PM
Solid Maple Flooring over OSB Ron6519 Remodeling 10 08-27-2009 12:52 AM
Storing Solid Hardwood prior to install gwoman Flooring 2 01-20-2009 07:27 AM
