Old 11-21-2011, 09:46 PM   #1
How to install Linoleum with infloor hydronic heating
Hi there. I'm having a technician install pex tubes onto my kitchen subfloor but I then want to install a linoleum floor on top. I believe I have to use self levelling concrete and then the flooring. Is there anything else I should do or be aware of? Do I have to 'dam' up the edges of the floor? Is this difficult for a fairly unexperienced DIY'er? Thanks!
corrinnao is offline   Reply With Quote
Old 11-22-2011, 06:50 AM   #2
Doer of Many Things
poppameth's Avatar
Before you even get to that part, are you going to be installing real Linoleum or a sheet vinyl? There is a huge difference.
poppameth is offline   Reply With Quote
Old 04-17-2012, 09:32 AM   #3
it will be VCTs (vinyl compost tiles) . Sorry about the late response!
Old 04-17-2012, 10:06 AM   #4
Pro Flooring Installer
rusty baker's Avatar
They are "vinyl composition tile". You need to ask the manufacturer of the heating system to see what is required.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 04-17-2012, 01:05 PM   #5
So the installer suggested just using their adhesive. I was wondering if there was anything else anyone suggest for ease of future removal/replacement. If not, the adhesive seems very straight forward.
Trying to install bamboo 5/8, backer board under my linoleum?!? ls3c6 Flooring 7 11-21-2011 02:29 AM
Hydronic Air PEX Piping Deteriorating - Repipe or Install New Heating System? aoreo HVAC 9 06-25-2010 08:36 PM
Heating element install ???? 50juan HVAC 1 05-18-2010 05:31 AM
go from hot water heating to forced air alex333 HVAC 22 08-08-2008 08:57 PM
Trane XE80 Heating Question, Please help!!! Stephen1977 HVAC 3 01-30-2007 07:34 PM
