How To Install Laminate Flooring In Bathroom - Flooring - DIY Chatroom Home Improvement Forum
Old 02-25-2014, 08:13 PM   #1
how to install laminate flooring in bathroom
We are getting ready to install laminate flooring in our bathroom have everything gutted .my question is do you install the laminate flooring around the toilet flange or under it and screw the flange back down through it? The flooring is Swiftlock Sierra Slate 8mm and underlayment padding underneath.
littlejohn1964 is offline   Reply With Quote
Old 02-25-2014, 08:23 PM   #2
Rewards Points: 236
"how to install laminate flooring in bathroom ?"
you don't. find something else.
Fix'n it is offline   Reply With Quote
The Following 2 Users Say Thank You to Fix'n it For This Useful Post:
littlejohn1964 (02-25-2014), Live_Oak (02-27-2014)
Old 02-25-2014, 09:41 PM   #3
Well we already have the flooring so we just need to know whats best under or around the flange?
Old 02-25-2014, 10:13 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 388
So, is this a full bath or powder room? What type of subfloor system?
Jaz
Old 02-25-2014, 10:16 PM   #5
It is a 3 piece bathroom(toilet,shower,vanity) two adults in home.
Osb subfloor
Old 02-25-2014, 10:21 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 388
I don't believe it's a recommended type of flooring for a 3 piece. Is this made by Armstrong or is it Shaw? Where did you buy it?
Jaz
Old 02-25-2014, 10:22 PM   #7
Armstrong, bought privately
Old 02-25-2014, 10:37 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 388
You bought it privately? Not sure what that means, but....
I can't recommend you using this stuff in a bathroom. Do the instructions tell you any different? I doubt it'll even pass your local code requirement. But even if the code is neutral on the subject, I wouldn't want a floating floor in a bathroom. A few spills and the subfloor gets damp and it'll take weeks for it to dry. It's not a sanitary floor.
Jaz
Old 02-25-2014, 10:39 PM   #9
ok thanks just wondered if we should apply under flange and bolt through it or leave an expansion gap around it then silicone gap to seal
Old 02-25-2014, 10:42 PM   #10
Tileguy
JazMan's Avatar
Rewards Points: 388
Hello...hello..is anybody home?
Jaz
Old 02-25-2014, 11:00 PM   #11
Rewards Points: 13,740
LAMINITE SHOULD NOT BE USED IN A BATHROOM!!!!!!!
#1 Laminate needs to float or it pulls it's self apart.
It full of seams where water can get under the floor.
Gets wet once and it's trash.
Old 02-26-2014, 01:05 AM   #12
Rewards Points: 29
Flange goes on top of finished floor. However, I agree with the rest of the inmates, laminate is not ideal for a bathroom of any type!
liljohnny is offline   Reply With Quote
Old 02-26-2014, 01:17 PM   #13
Thanks to all, I'll let you know how it turns out.
Old 02-26-2014, 01:30 PM   #14
Jb1234's Avatar
Rewards Points: 87
Haha. Well so much for taking advice. This would be even worse than having carpeting in there. Chances are it won't last, and if you don't keep the proper expansion all around it you're inviting disaster again.
Jb1234 is offline   Reply With Quote
Old 02-26-2014, 04:11 PM   #15
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 126
Oh well. I wonder sometimes why we waste our time on here.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 06:37 PM
Which direction to install laminate flooring - Floorplan attached oONightFireOo Flooring 8 01-31-2010 03:01 PM
I want to install laminate plank flooring but have problem with sub floor In the Bush Flooring 3 04-29-2009 12:35 PM
Questions about and Use of Laminate Flooring ORHarleyman Flooring 3 04-29-2009 12:04 PM
Bathroom and laminate flooring impvme Flooring 4 07-21-2008 03:01 PM
