How To Install Flush Mount Vent In A Finished Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-10-2012, 11:29 AM   #1
how to install flush mount vent in a finished floor?
I need to install a flush mount vent frame in a finished hard wood floor.
What options do I have?
1. Rip out the portion of the floor needed to do the job?
2. Make a plywood template and use it as a guide for the router?
Please let me know if I have any other options?
net_tech is offline   Reply With Quote
Old 02-10-2012, 10:54 PM   #2
remodeling pro
Position the frame exactly on the floor, then using some 2 1/2" or so wide strips create a "picture frame" around the vent frame, securing the strips to the floor with double stick tape. Remove the vent frame and use a 1/2" top bearing bit to rout inside the picture frame to the proper depth for a flush fit. Carefully square the radiused corners with a sharp chisel.
troubleseeker is offline   Reply With Quote
Old 02-11-2012, 07:04 AM   #3
Rewards Points: 13,458
Why? They sell wooden drop in ones at lowes and Home Depot.
Old 02-11-2012, 07:23 AM   #4
DIY staff
Rewards Points: 7,174
The directions are good--except the router will hit the wall --making the walll cut impossible---use a multi-tool to cut those areas that the router can't reach.
Old 02-13-2012, 10:03 PM   #5
remodeling pro
Judging by the relationship of the metal duct and width of the frame for the drop in vent compared to the floor boards, I'd guess that is 4 or 4 1/4" strips. As you observe, even with the qrtr round removed, it may be too tight for a full size router, but a trim router or laminate trimmer should fit ok. A multi tool used with a straight edge guide will certainly work, but I think it will be much more difficult to obtain a quality fit.
The Following User Says Thank You to troubleseeker For This Useful Post:
oh'mike (02-14-2012)
Old 02-13-2012, 10:08 PM   #6
Still wondering why you want to do all this work where a drop in would work better, and at some point it's all going to have to be pryed off if the floor needs refinishing.
http://floorregisters.net/
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Poor toilet flush - vent related? WaldenL Plumbing 10 08-24-2009 10:54 AM
Replace forced air heat vent with radiant floor malfunction HVAC 9 02-05-2009 12:01 PM
Can I install 3/4" HW on top of the rolled floor membrane there now? davevarga Flooring 3 03-09-2008 10:16 PM
laminate floor vs subfloor 4 railing mount gdub Flooring 4 01-04-2008 02:42 PM
