How Hot Can I Turn Up My Floor Heat? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-16-2010, 08:55 PM   #1
Just call me Andrew
Rewards Points: 1,020
How hot can I turn up my floor heat?
New bathroom - how hot is too hot (ie. what will damage the tile?)
Porcelain tile, epoxy-modified grout, latex-modified mortar.
Thanks!
Andrew
secutanudu is offline   Reply With Quote
Old 05-16-2010, 09:04 PM   #2
I've never turned mine past 76
Never needed to
Old 05-16-2010, 09:06 PM   #3
Just call me Andrew
Really? The default on the thing is like 82...I was wondering if I could go hotter.
Andrew
Old 05-16-2010, 09:14 PM   #4
We usually keep it around 68-70, down to 65 at nite
We only turn it up to 74-6 for our sons bath
Old 05-16-2010, 10:38 PM   #5
Just call me Andrew
Maybe your mortar/tiles allow more heat to pass through than mine? Are you trying to get the floors warm, or just take the edge off?
Andrew
Old 05-16-2010, 10:58 PM   #6
If I have it set to 70 the floor feels warm
Are you on a cement slab ?
I'd almost think that tile is good for 100, if not much higher
Old 05-16-2010, 11:01 PM   #7
Just call me Andrew
Nope, basement is below. Mat is laid on top of hardi-board under the tiles.
I am assuming porcelain can go way higher - i was thinking more about the grout. I mean, they make porcelain-enameled grill racks. The directions only mention that you may damage wood and laminate floors if you go above 83F, they don't mention tile.
The bathroom is so small (15 sq foot mat, ~1 Amp) I don't really mind running it nice and warm.
Andrew
Old 05-16-2010, 11:07 PM   #8
Not sure about the grout
I think I'd keep it around 75 since its a small matt
Ours is turned off for the summer, since last month
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
blower won't turn on when heat is on, but will turn on when AC is on wavelength HVAC 6 12-31-2009 05:06 PM
Fan and A/C unit won't turn on cadmanim HVAC 1 06-22-2009 03:49 PM
Furnace w Cooling unit wont turn off Klatimer HVAC 2 09-19-2008 09:35 PM
Faucet won't turn off etiger Plumbing 1 08-31-2005 03:46 AM
