How Forgiving Is Ditra? - Flooring - DIY Chatroom Home Improvement Forum
Old 10-13-2011, 12:31 AM   #1
How forgiving is Ditra?
I'm going to re-tile almost 800 square feet. I just pulled up all of the old tile that was adhered directly to the subfloor (no backerboard, no Ditra). Most of the tiles popped up with a floor scraper very easily but there was a little bit of thinset left on the plywood.
For the last two weeks, we have been using a floor scraper and a 3x21 (small I know) belt sander to try to get the floor as smooth and flat as possible. It looks MUCH better now but there are still some areas where this is a LITTLE bit of thinset. There are also a few screw heads that are barely sticking up above the plywood. I hit them when I use the floor scraper.
If I use Ditra, do I need to even worry about making the subfloor as smooth as possible, or will the modified thinset and Ditra work ok with a not-so smooth/flat surface. I feel like I could scrape and sand for two more weeks and still not get it down to bare plywood.
Any suggestions would be appreciated! Thanks!
stankholio is offline   Reply With Quote
Tags
ditra , subfloor , tile adhesives
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
Ditra on covered Balcony Siegelpmp Flooring 2 09-11-2011 09:06 PM
confusion over thinsets for installing Ditra over heated flooring fhknox Flooring 12 01-19-2009 07:21 PM
Ditra vs. Ditra XL richbl Flooring 3 10-13-2008 10:07 AM
