How Flat Do I Need To Get My Slab Before I Install Laminate Flooring? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-21-2011, 11:05 PM   #1
How flat do I need to get my slab before I install laminate flooring?
How flat do I need to get my slab before I install laminate flooring? I am installing Harmonics Vineyard Cherry http://harmonics-flooring.com/products.cfm?item=11 over an old funky slab. I have been hitting it with a self leveling concrete and things are looking much better but there are still some spots that sage 1/8" or so in 4'. I am planning to hit those spots with some more SLC but am wondering when I should call it good. Also are there any tricks other than SLC to fix the small problems in the sub floor?
Thanks for any help
Dave
Dave K is offline   Reply With Quote
Old 08-21-2011, 11:50 PM   #2
Rewards Points: 200
Follow Manufactures guidelines .
1/8" in 6' or 3/16" in 10'
Floor Doc is offline   Reply With Quote
Old 08-22-2011, 09:52 AM   #3
Tile with Style
BlueStoneFloors's Avatar
Dave it sounds like you are doing a real good job Just keep at it with the level and patch until it's as good as possible. Perfect isn't going to happen with your situation, obviously.
Hell is 8 months of nothing but slate work...
BlueStoneFloors is offline   Reply With Quote
Old 08-22-2011, 02:36 PM   #4
Rewards Points: 200
I just inspected a glue down that the installer followed builders association guidelines of 1/4" in 4'
Looks like the tide is coming in . Lady has $10,000 of firewood on her floor .
Old 08-23-2011, 04:30 PM   #5
Tile with Style
LOL, funny... Thank god for self leveler
Old 08-23-2011, 06:47 PM   #6
I just finished grinding paint off my basement floor. Sucked.
Getting ready to hit with Diamond wheel before self leveling.
I plan on putting the Tyroc subfloor before laminate floor.
Any tips for using the self leveling compound? If you do in stages like the OP is doing do you just re prime the existing floor level spots before tying in to it?
seamus Mc is offline   Reply With Quote
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 06:37 PM
Laminate flooring and such for kitchen christineka Flooring 5 01-04-2011 07:08 AM
Flooring over slab mike6x7 Flooring 1 01-07-2010 07:42 AM
Laminate Flooring - few questions AZ-Electrical Flooring 2 05-15-2009 07:52 AM
How do you install a toilet over Laminate? yohan Flooring 6 07-22-2008 07:07 AM
