How To Fix Tile Crack - Flooring - DIY Chatroom Home Improvement Forum
Old 08-16-2012, 01:51 AM   #1
How to Fix Tile Crack
Have couple tiles cracked but don't want to replace them. Is there a good way to fill the crack and seal it?
diy1618 is offline   Reply With Quote
Old 08-16-2012, 02:55 AM   #2
What is "tile filler", is it some item available in stores?
Originally Posted by Kamya View Post
Mix some matching paint (a paint store can match the color of your tile) with tile filler, and dab it onto the crack with a cotton swab.
Allow the tile filler to dry for a few seconds, then wipe lightly with a damp cloth. When you're done, the crack will be much less visible
Old 08-16-2012, 04:52 AM   #3
DIY staff
Rewards Points: 7,174
Never heard of that----
Epoxy mixed with a colored pigment might work---
diy1618 (08-16-2012)
Old 08-16-2012, 06:55 AM   #4
Pro
JetSwet's Avatar
Rewards Points: 502
How did they crack in the 1st place? Any sealer will not work for long. If a tile cracks then there will be movement in the tile it's self.
JetSwet is offline   Reply With Quote
Old 08-16-2012, 10:38 AM   #5
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Where is the tile (floor? shower? etc.)
A pic may help.
Odds are any repair will be more obvious than the crack, and if it is in a shower, you want to do it right.
Old 08-16-2012, 01:12 PM   #6
It's floor tile. I don't know how it can crack because it was there when we purchased the house. The crack is not that noticeable, I just want to fill it so that it will not get worse.
Old 08-16-2012, 01:13 PM   #7
Any suggestion on where to get the "colored pigment"?
Old 08-16-2012, 02:09 PM   #8
Rewards Points: 13,752
Tile most often cracks because the subflooring, underlayment or floor joist are undersized or just done wrong.
Any filler, caulking what ever is just going to make the crack more noticable, not stop it from cracking more.
The only right way to fix it is to remove and replace, even that may still crack again if the floor below it was built wrong.
Tile can not have any movement below it.
JetSwet (08-16-2012)
Old 08-17-2012, 03:29 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Expect more cracks.
Old 08-17-2012, 03:53 PM   #10
This is a relatively new house and I believe the tiles are original, and the subfloor should be ok when it was built. The crack is very fine line and that's why I want to fill it.
If I have to replace the tiles, I still want to just replace the cracked ones. What is the proper way to do it then? How can I prepare the subfloor just under the tile?
Old 08-17-2012, 05:56 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If the tiles were installed properly and the substrate was adequate you wouldn't have tiles cracking. A cracked tile could have a razor sharp edge at the break-point so be very careful.
Filling the crack will do nothing. It won't save the tile, it won't change the crack, it won't [repair] anything.
You can expect other tiles to follow suite in the future.
The substrate is not properly prepared or suitable for a tile installation and that is your problem. It isn't the tile it is the substrate.
Old 08-17-2012, 06:52 PM   #12
If you want to remoove atile use have to first remove the grout around it.
I use an ossilating saw with a diamond blade but a simple cheap hand grout saw will also work. Home Depot and Lowes will have them in the flooring area.
Once the grouts out you can break the tile in an X shape from corner to corner with a brick chisle.
Once it's all chipped out clean off the surface under it until it's all flat.
Use Thin set in a bag to install the new tile.
Just because a house is new does not mean the floor joist, subflooring and underlayment were sutable to lay tile over it.
diy1618 (08-17-2012)
Old 08-17-2012, 07:07 PM   #13
If the surface is not flat, what stuff I can use to make it flat?
What do you mean by "Thin set in a bag"?
Old 08-17-2012, 07:56 PM   #14
Paint scraper, sander, putty knife, chisle, whatever it takes.
Just that, thin set is what a real tile setter uses, anything premixed, or trying to cheap out and using a mastic is subject to failure.
It gives a solid hard bond so there not going to just come loose.
It's sold in the flooring dept. at Lowes, Home Depot, any hardware store.
It comes in a bag, just add water.
Old 08-17-2012, 08:05 PM   #15
DIY staff
I use powdered tempura paint---I use this mix for wood working--filling in the void where a tool blade enters a ferrule when making lathe tools and such.
Should work for any tile crack.
Like others have said---the tile cracked because it is unsupported--so this will be a temporary repair.
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
new ceramic tile over 12x12 ceramic danthebuilder Tiling, ceramics, marble 4 08-09-2011 12:03 PM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 03:06 PM
Vertical tile on wall poolecw Flooring 2 06-01-2010 10:05 AM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
