How To Fix Minor Water Damage On Hardwood Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-01-2015, 08:40 AM   #1
Rewards Points: 502
How to fix minor water damage on hardwood floor?
I accidentally spilled water on my precious hardwood floor, and have caused some minor visible damage. As a result, the floor doesn't look completely flat. See attached photo.
Please advise how to get this fixed.
HomeLearner is offline   Reply With Quote
Old 01-01-2015, 08:56 AM   #2
Rewards Points: 1,598
Sure that's not a laminate floor?
mako1 is offline   Reply With Quote
Old 01-01-2015, 09:14 AM   #3
Rewards Points: 2,180
Sure looks like laminate flooring with moisture issues that can not be fixed.
What's under it? A slab?
Old 01-01-2015, 10:15 AM   #4
Rewards Points: 502
It is said to be tiger hardwood floor. Underneath may be concrete.
Old 01-01-2015, 10:33 AM   #5
ZZZZZ's Avatar
Rewards Points: 608
"tiger wood" may just be the color or the style.
Hardwood or laminate, whoever installed it didn't do a very good job of staggering the butt joints. They're very close together on alternate rows.
ZZZZZ is online now   Reply With Quote
Old 01-01-2015, 10:34 AM   #6
Rewards Points: 502
Whoever installed it, they didn't do a very good job of staggering the seams.
Will the moisture disappear with time if I don't do anything about it? Or do I need to press the damaged areas to flatten?
Old 01-01-2015, 03:42 PM   #7
There is no "fixing" it.
Once it's delaminated it's trash.
There is no letting it dry out and it will go back.
Leave it there and at some point molds going to set in making a bigger problem.
Who's telling you it's hardwood?
Sure looks like laminate or engineered flooring not real hardwood flooring.
The micro bevels make me think of engineered flooring.
Old 01-01-2015, 04:06 PM   #8
Rewards Points: 502
I attach a photo showing the texture of the hardwood floor. It's firm and doesn't look cheap. Does it make any difference if it's real hardwood floor?
What would happen if the molds set in? Shall I use heat to dry up the area?
Old 01-01-2015, 04:44 PM   #9
DIY staff
Rewards Points: 4,514
A skilled installer can replace individual boards---that is a tough job and requires a bit of time----make some calls--see if the manufacturer has a list of certified installers
Sanding methods for uneven hardwood floors inquisitiveblue Flooring 3 08-05-2011 10:49 AM
Floor damage from a 2nd floor bathroom toilet leak Tamber Plumbing 3 05-02-2011 11:10 PM
Hardwood floor is buckling again Kerm Flooring 1 05-07-2010 05:35 PM
unique problem with hardwood floor seanbellay Flooring 15 05-02-2010 06:53 PM
hardwood floor transition from old to new cooter Flooring 4 05-25-2009 10:20 AM
