Old 01-13-2013, 12:00 PM   #1
How to fix damaged vinyl floor roll
Hi, we have a 500 sq ft room behind our house that we access through a covered walkway. After we bought the house we discovered a corner of the foundation had broken away. That has been repaired, but now the corner of the vinyl floor has been torn away. It's a roll of vinyl and it's dated, so the chances of finding something that matches to patch it with are slim. I've been looking at options for putting a new floor down, but they're all $300+ so I thought I would ask a forum for cheap ideas for fixing. This is my hail mary pass before having to replace the whole floor. Any ideas (picture attached)?
harolde7878 is offline   Reply With Quote
Old 01-14-2013, 05:10 PM   #2
WindowTreatment Installer
That pattern looks pretty common. You should be able to find something close in a peel and stick vinyl tile. I would try to find the closes peel and stick. All you need is 4 tiles. Lay all 4 down in the corner and then trace the the outer edge. Then remove the existing flooring up to the traced line and lay the 4 new tiles into place. That should be a good fix other then replacing the whole floor.
bobtheblindguy is offline   Reply With Quote
framing for vinyl wind barrier (See photos) Carolyn252 Building & Construction 2 09-02-2011 05:50 PM
vinyl sheet or tile (or allure) over old vinyl? thomase Flooring 8 06-30-2008 06:15 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
