How To Fix Air Bubble In Laminate Stair Nose? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-06-2010, 01:30 AM   #1
How to fix air bubble in laminate stair nose?
so i glued down the stair nose with construction adhensive glue, nail gunned.
next day, i got air bubbles coming out from the surface, i used the iron and towel technique, but it still won't go away, i even tried poking a hole with a pin to let the air out, but still no use. it turned out like these.
what should i do?
i want to avoid redoing it becuz i've got it glued underneath, and it will be a very hard work to take the stairnose back out.
someone help please?
babiboi31 is offline   Reply With Quote
Question on installing pergo stair nose amaruenterprise Carpentry 11 10-11-2009 05:21 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
LAMINATE STAIR: with or without underlayment nathan.tran Flooring 1 08-19-2008 01:24 AM
Laminate Stair Nosing/Riser question QuestAns Flooring 1 02-15-2007 08:02 AM
proper way to install laminate on stair KUIPORNG Flooring 3 11-21-2006 08:16 AM
