Old 07-22-2011, 01:39 AM   #1
How to fill holes in concrete after demo job.
I just took out 30-year-old tile from my parents' house. Now the concrete slab has a bunch of holes. How do I get everything flat? Is there something I can pour onto the floor to get everything flat and level?
THANKS!
kpshulman is offline   Reply With Quote
Old 07-22-2011, 07:05 AM   #2
Super Moderator
Yes, There is----It's called self leveling compound. SLC can not be used as a finish finish surface as it is to soft to take traffic.
What are you putting on top of the concrete?
Old 07-22-2011, 10:21 PM   #3
I will be putting tile back on. Can I tile directly on the SLC? Do I need to do any prep prior to using the SLC? THANKS!
Old 07-23-2011, 09:08 PM   #4
Super Moderator
That's exactly what self leveling compound is designed to do,Tile.
In a nut shell--clean floor---prime with the recommended primer--mix with very cold water--
dump on floor---quickly push it around to help it level.--Add more for a deeper hole.
It is very important to read the instructions---and work fast.
I use one that is mixed with a liquid latex for the first coat--I've never had bond failure with this one.
However,I believe most brands work just as well.
---Mike---
Do I need a form for the concrete pier or just fill up the hole I dug? graysqwrl Building & Construction 1 07-20-2011 08:44 PM
Concrete Block Core Holes john4153 Building & Construction 1 12-24-2010 12:08 AM
3" gap between concrete driveway and garage floor need to fill frankrizzo Building & Construction 0 11-23-2010 09:08 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
do not use concrete filler to fill stones... KUIPORNG Landscaping & Lawn Care 4 08-29-2008 05:16 PM
