Old 12-07-2012, 12:52 AM   #1
How to drill small holes in tile
I need to drill a couple of tiny holes in my tile back splash..
Basically im replacing all my light switches with the flat rocker style.
The new switches overhang on the tile just a hair so that went I try to screw the face plate on the screws hit the tile. So basically I just need to drill 3 small holes that the face plate screws can go into.
Do I just use a regular drill bit? I was just worried about the tile cracking, even though these will be small holes.
Robert95z is offline   Reply With Quote
Old 12-07-2012, 01:28 AM   #2
You can use carbide tipped masonry drill bits or diamond tipped drill bits. The diamond tipped bits are more durable and are best for drilling into very hard tiles more expensive, but they will not burn out as easily as the masonry bits. Note; when drilling into tile make sure you have a wet sponge dripping over the drill bite while drilling the hole as it will keep the bit cool and won’t make dust.
epson is offline   Reply With Quote
Old 12-07-2012, 08:35 AM   #3
If these holes are really close to the edge of the hole where the box is I'd just use a Roto zip with a tile bit instead of a drill.
Old 12-07-2012, 08:52 AM   #4
Also they make regular bits that are for glass and tile. almost any bit you use will need you to take a punch tap it lightly but firm enough to break the glaze so the bit doesn,t wander all over the place.If these holes are near the edge this is likely to crack the tiles. The Roto-zip as previously mentioned with the tile bit and eat away at the edge may be your best bet.
Old 12-23-2012, 07:56 PM   #5
OP is probably long gone but I use a small piece of oak as a guide for the ceramic bit. Drill the same size hole in the oak and use duct tape to hold the wood guide in place. Works great at keeping the bit from drifting, almost like using a drill press.
philS is offline   Reply With Quote
Old 12-23-2012, 08:06 PM   #6
I took care of it.. used a masonry bit and got the job done.. thanks
Old 12-25-2012, 01:27 AM   #7
or, place masking tape over the spot you're going to drill. drill through the tape. the tape will keep the bit from walking
Seattle2k is offline   Reply With Quote
Old 12-25-2012, 07:51 AM   #8
I've had success marking the spot with a felt pen, cutting through the glaze with a Dremel and then using a regular twist drill.
Fairview is offline   Reply With Quote
Drill holes through cement tile? Dwillems Roofing/Siding 9 03-07-2012 11:50 PM
How many holes can I drill into a wood stud? lostintyme Building & Construction 8 02-28-2012 08:26 PM
Drill bits for tile? jdraughn Tools 18 12-14-2009 10:30 AM
Best tool to drill holes in Porcelain tile theedudenator Tiling, ceramics, marble 6 12-09-2009 07:44 PM
How to Drill Porcelin/Ceramic Wall Tile tmbrink Kitchen & Bath Remodeling 3 02-27-2009 07:14 PM
