-   -   How to drill small holes in tile (http://www.diychatroom.com/f5/how-drill-small-holes-tile-165812/)
Robert95z 12-07-2012 12:52 AM
I need to drill a couple of tiny holes in my tile back splash..
Basically im replacing all my light switches with the flat rocker style.
The new switches overhang on the tile just a hair so that went I try to screw the face plate on the screws hit the tile. So basically I just need to drill 3 small holes that the face plate screws can go into.
Do I just use a regular drill bit? I was just worried about the tile cracking, even though these will be small holes.
epson 12-07-2012 01:28 AM
You can use carbide tipped masonry drill bits or diamond tipped drill bits. The diamond tipped bits are more durable and are best for drilling into very hard tiles more expensive, but they will not burn out as easily as the masonry bits. Note; when drilling into tile make sure you have a wet sponge dripping over the drill bite while drilling the hole as it will keep the bit cool and won’t make dust.
joecaption 12-07-2012 08:35 AM
If these holes are really close to the edge of the hole where the box is I'd just use a Roto zip with a tile bit instead of a drill.
ToolSeeker 12-07-2012 08:52 AM
Also they make regular bits that are for glass and tile. almost any bit you use will need you to take a punch tap it lightly but firm enough to break the glaze so the bit doesn,t wander all over the place.If these holes are near the edge this is likely to crack the tiles. The Roto-zip as previously mentioned with the tile bit and eat away at the edge may be your best bet.
philS 12-23-2012 07:56 PM
OP is probably long gone but I use a small piece of oak as a guide for the ceramic bit. Drill the same size hole in the oak and use duct tape to hold the wood guide in place. Works great at keeping the bit from drifting, almost like using a drill press.
Robert95z 12-23-2012 08:06 PM
I took care of it.. used a masonry bit and got the job done.. thanks
Seattle2k 12-25-2012 01:27 AM
or, place masking tape over the spot you're going to drill. drill through the tape. the tape will keep the bit from walking
SeniorSitizen 12-25-2012 07:51 AM
I've had success marking the spot with a felt pen, cutting through the glaze with a Dremel and then using a regular twist drill.
