How Do You Figure Floor Flex? - Flooring - Page 4 - DIY Chatroom Home Improvement Forum
Old 01-27-2012, 06:34 PM   #46
analogmusicman's Avatar
Rewards Points: 560
Good to hear from you again Jaz. yeah,since your "signature" says you do "Ditra" installs, you must not dislike it too much.
anyway,since you do lots of floors, in your opinion,would it look "shlocky" if I do my kitchen in a "diagonal" pattern and my laundry room in a regular square pattern? (the two areas are right next to each other,separated by a door) I'm SERIOUS,my "assistant" and I may need "marriage counseling"
tnx,
analogmusicman is offline   Reply With Quote
Old 01-27-2012, 06:49 PM   #47
Tileguy
JazMan's Avatar
Rewards Points: 412
Yup, still here. I prefer Ditra even though it ends up costing me more money and also takes more time to finish the job in most cases. On the positive side it's a better installation, lighter, thinner.
You can change layout at the doorway, it's a personal thing. I would make the change with a row of 4.5" tiles offset from the straight-set tiles.
I do consulting, but no counseling.
Jaz
Old 01-29-2012, 10:21 AM   #48
Originally Posted by JazMan View Post
In the end this is more of an art and not science
Science promises consistency, more or less regardless of installer skill but art depends on the installer and can help or hurt.
This doesn't sound so good.
Old 01-31-2012, 09:45 PM   #49
Rewards Points: 560
so,Jaz,when you lay down "Ditra" as an underlayment for your tiles in a bathroom,should the seams be "taped" ala "backerboard"?
tnx,
Old 02-01-2012, 01:00 AM   #50
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Have you checked out Schluter's web page? They have instillation instructions etc.
http://www.schluter.com/2080.aspx
http://www.schluter.com/6_1_ditra.aspx
Old 02-01-2012, 12:52 PM   #51
Rewards Points: 560
thanks for the links "blondesense",that answered the question pretty much,you use "Kerdi-band" kind of like you use the tape on CBU seams. just wondering though if you can do like CBU and put down the "Kerdi-band" as you lay tiles to avoid the "speed-bumps". also,the manual says you should seal the floor/wall transitions too,you don't do that with CBU,right?
tnx,
Old 02-01-2012, 04:38 PM   #52
Tileguy
JazMan's Avatar
Rewards Points: 412
It's difficult to totally waterproof a floor that isn't built like a shower. Usually there is no reason to build a floor that can hold water. If you need to do that however, Kerdi Band the seams and also flash up the walls. I have no idea what you'll do with the doorways and jamb/casing areas.
There will be a very slight build-up with Kerdi Band since it's only 4 mils thick. It's not a problem as it can be with CBU's if you're not careful.
Jaz
Coping Trim? I just can't figure it out!? Evil Scotsman Carpentry 22 05-08-2011 07:45 PM
American Standard Heat Pump Freezing up! Tech can't figure it out. desertsage HVAC 6 01-02-2011 12:33 PM
Help me figure out what to do with my backyard! atcnick Landscaping & Lawn Care 7 01-26-2010 08:28 PM
Gimme a book, I'll figure it out soccio97 Introductions 1 09-03-2008 08:15 PM
How does a person figure a bid for sheetrock finish and painting? michell Painting 3 08-11-2008 04:23 PM
