How Do You Figure Floor Flex? - Flooring - Page 3 - DIY Chatroom Home Improvement Forum
Old 04-14-2011, 10:57 PM   #31
Tileguy
JazMan's Avatar
Rewards Points: 412
1) how much tile should I get for a floor that's 42 sq. ft. I know you should get some extra.
On small jobs like that I often figure by the piece too just to double check. Also depends on how it's packaged. Are you gonna cut tiles to make base moldings too? Normally I's say 3-5% extra, but on small areas 10% may be smarter.
2) is "Hydroment" good thinset? I'm thinking of getting some of the less expensive stuff for the bath and save the "Reflex" for the kitchen.
Hydroment is the brand name, they make all qualities.
3) how thick should the thinset be?
Do you mean the consistency, or which trowel to use? I don't remember you making a selection yet. Consistency, kinda like mashed potatoes, and no lumps.
4) is the "backer board" at HD ok? 1/4"?
Sure, it's fine. Sometimes it's dried out cuz they buy in large quantities and it sits there a long time. But it starts out the same. Which one are you leaning towards?
5) don't have to seal the joints in the backer,right?
What do you mean by seal? You apply the special tape and a film of thin set.
6) how long does regular thinset remain workable? a couple hours in the bucket you mix it in?
Depends on ambient conditions but you can figure 2-3 hours. Be sure to stir with margin trowel every now & then.
Your welcome,
Jaz
Old 04-15-2011, 12:11 PM   #32
analogmusicman's Avatar
Rewards Points: 560
Your welcome,
Jaz
thanks for the answers Jaz, some more questions:
OK,I'll be going over to "Bedrosian's on Mon. to get my stuff.
yeah, the bath is a small job and I'm sure a bag of thinset will do it. just wondering how thick the bed of thinset should be, or should I even worry about that?, just slap it on with the "notched trowel? making sure at least 80% of the tile contacts the thinset?)
I'm buying "bullnose" to go around the edge where the baseboard was.
the kitchen is about 208 sq. ft. you think maybe a couple 50# bags of the good stuff'll do it?
what I meant by "sealing" is the joints between the backer board. I must've misunderstood about that. so those joints have to be covered with the special tape and thinset?
the backer board is screwed down with special screws,right? how far apart should they be?
does the grout have to be sealed?
tnx,
analogmusicman is offline   Reply With Quote
Old 04-15-2011, 06:40 PM   #33
Rewards Points: 560
Jaz,
rather than have you spend all your time answering questions, I went to Lowe's and bought a book for $10. it seems ok,has lots of info.
tnx,
Old 04-15-2011, 09:44 PM   #34
Tileguy
JazMan's Avatar
Rewards Points: 412
OH, OH, depending on the book you might be in trouble now.... We've seen some real goofy, out of date info in some books. Esp. the ones from the publisher whos name start with a "T".
Jaz
Old 04-16-2011, 09:41 AM   #35
Rewards Points: 560
Jaz
well, I WAS wondering about a few things I read. like they showed somebody putting tile right on the sub-floor. didn't somebody,somewhere, tell me you ALWAYS put on "backerboard"? (or some kind of underlayment?) and this other book I read at Lowe's showed "backerboard" being layed down on a layer of thinset. not a word about that in MY book. confusing!
tnx,
Old 04-16-2011, 10:20 AM   #36
Tileguy
JazMan's Avatar
Rewards Points: 412
DAHHHHHHH!
Are books refundable?
Jaz
Old 04-16-2011, 10:23 AM   #37
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Go get your money back for that book! Hell, you can come here for free. Is that one of those Taunton Press books? Commonly referred to as : Taunting Press.
XXX
Old 04-16-2011, 05:44 PM   #38
Rewards Points: 560
didn't I see a sign at Lowe's saying books aren't refundable?but if they ARE,I'll surely return it!
anyhoo...here's something "the book" didn't talk about:
if you're putting "bullnose" around the edge of the floor as your "baseboard", do you still leave a 3/8" gap between the tile and the wall?
(for expansion?) does any grout go in that gap or do you just leave it empty (my vote is for empty but then YOU GUYS are the experts!) then how about the "bullnose"? I suppose you thinset it right to the wallboard? then what about the grout? there's supposed to be grout between the tile and the bullnose,right? if you stick grout in there,your gap gets filled up,right? (so maybe the gap DOES get filled with grout!)
questions,questions,questions...
tnx,
Old 04-16-2011, 07:27 PM   #39
Tileguy
Bud Cline's Avatar
Rewards Points: 558
A minimum gap of 1/4" is required, fllor tile to wall. No filling of that gap with anything unless you want to caulk it. The bullnose baseboard then covers that gap and should be about 1/16" to 1/8" above the tile floor. THAT GAP then gets caulked. Any change-in-plane should be caulked. The spaces between the bullnose can be grouted. The original floor to wall gap remains empty of fill and hidden.
XXX
Old 04-16-2011, 09:57 PM   #40
Rewards Points: 560
good info,Bud. I imagine silicone caulk would be ok in the gap then that same caulk could be used between the bullnose and the floor.
tnx,
Old 04-16-2011, 10:01 PM   #41
Tileguy
JazMan's Avatar
Rewards Points: 412
I closed this thread and immediately see you posted. Good timing.
Use whatever caulk you're comfortable with. Me......I don't like pure silicone. Every grout maker makes siliconized acrylic caulk to match their grouts, both sanded and unsanded. That's what I recommend.
As far as procedure, Bud said it perfectly.
Jaz
Old 04-17-2011, 11:04 AM   #42
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I don't use 100% silicone caulk either. Way too messy and ruins a lot of things.
XXX
Old 01-09-2012, 10:30 PM   #43
Rewards Points: 560
you still around Jaz? did I ever tell you I bought 3 bags of that "reflex" mortar in anticipation of my kitchen "re-model"?
well,anyway,the time to start all that is fast approaching. we'll start with the laundry room and proceed to the kitchen if my "assistant" and I are still talking!(that bathroom floor we did last year was "stressful")
be prepared for lots of questions.
tnx,
Old 01-27-2012, 05:27 PM   #44
Rewards Points: 560
so,what's better, "Ditra" or "cement backer board" as far as a "sub-strate" for laying tiles?
tnx,
Old 01-27-2012, 06:22 PM   #45
Tileguy
JazMan's Avatar
Rewards Points: 412
I'm sure you already know what I think.
Jaz
Coping Trim? I just can't figure it out!? Evil Scotsman Carpentry 22 05-08-2011 07:45 PM
American Standard Heat Pump Freezing up! Tech can't figure it out. desertsage HVAC 6 01-02-2011 12:33 PM
Help me figure out what to do with my backyard! atcnick Landscaping & Lawn Care 7 01-26-2010 08:28 PM
Gimme a book, I'll figure it out soccio97 Introductions 1 09-03-2008 08:15 PM
How does a person figure a bid for sheetrock finish and painting? michell Painting 3 08-11-2008 04:23 PM
