How Do You Cut Laminate? - Flooring - DIY Chatroom Home Improvement Forum
Old 10-08-2013, 09:11 AM   #1
Rewards Points: 578
How do you cut laminate?
I know they have a special cutting tool for laminate but at this point (beings the fact that i never plan to put down laminate again) i do not wish to purchase another tool. Is there any other way to cut it? I have a circ saw, a recip saw, a jigsaw, and an oscillating multi-tool. Is there hope or am i SOL?
Come and see the progress on my mobile home paradise!!! (NEW PICS ADDED ON 01/26/15!!)
http://www.diychatroom.com/f49/compl...emodel-168570/
TrailerParadise is offline   Reply With Quote
Old 10-08-2013, 09:17 AM   #2
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 978
Anything that will cut it. A skillsaw, jigsaw, sharp knife, not so good,...etc.
You will need a router with a trimmer bit to take down the extra material that you leave when working with the laminate. It can not be cut exactly and then glued on.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
Old 10-08-2013, 09:23 AM   #3
Rewards Points: 578
I mean floating laminate... not glued. Just floating and covered at the edges with baseboard trim
Old 10-08-2013, 11:40 AM   #4
123pugsy's Avatar
Rewards Points: 978
Ha, and here I thought I actually knew the answer to your question....DUH....
I it were me I'd probably use a chop saw.
Old 10-08-2013, 01:20 PM   #5
Oso954's Avatar
Rewards Points: 1,030
A chop saw is definitely quicker, but it can be done with a circular saw.
If you use a speed square as a saw guide your cuts should be straighter. Marking and cutting from the back of the board will minimize chipping with the circular saw.
Oso954 is offline   Reply With Quote
Old 10-08-2013, 02:40 PM   #6
Rewards Points: 578
i can use a chopsaw, ive got one of those. Do i cut with the finished side up, or the back side up?
Old 10-08-2013, 02:51 PM   #7
Rewards Points: 2,238
Cut with the finished side down -
Saw-blade with, as many teeth you can get (carbide).
rossfingal is offline   Reply With Quote
The Following User Says Thank You to rossfingal For This Useful Post:
Oso954 (10-08-2013)
Old 10-08-2013, 03:09 PM   #8
Rewards Points: 578
thanks. my saw has a carbide blade but im not sure how many teeth. Guess i can give it a try and cut the first board a little longer than i need to see if it cuts smooth enough. Thanks for the help!
Old 10-08-2013, 03:22 PM   #9
Oso954's Avatar
Go buy the blade ! Something like this.
http://www.amazon.com/Irwin-Industri.../dp/B000089H9G
Cutting laminate is hard on sawblades. Consider it an expendable.
Old 10-08-2013, 03:49 PM   #10
Rewards Points: 3,532
" can use a chopsaw, ive got one of those. Do i cut with the finished side up, or the back side up? "
A miter saw,table saw,or radial arm saw,cut with face side up,only face down with a circular saw.
Canarywood1 is offline   Reply With Quote
Old 10-08-2013, 08:52 PM   #11
I always thought it didn't matter. If your cuts show up your not doing it right. X2 on the ruining of a blade lol
big juicy01 is offline   Reply With Quote
Old 10-09-2013, 08:59 PM   #12
Davejss's Avatar
Rewards Points: 746
I always use a jig saw. Its right there on the floor with me. No getting up and down a thousand times. All of your cuts are going to be hidden under molding so no need for a perfect cut. Also handy for notching and so forth.
Davejss is offline   Reply With Quote
Re-using laminate wingman1153 Building & Construction 10 04-30-2013 11:51 AM
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
laminate moving in one direction nlmedic Flooring 2 03-01-2011 07:38 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 12:04 AM
