-   -   How do you cut laminate? (http://www.diychatroom.com/f5/how-do-you-cut-laminate-188257/)
TrailerParadise 10-08-2013 09:11 AM
I know they have a special cutting tool for laminate but at this point (beings the fact that i never plan to put down laminate again) i do not wish to purchase another tool. Is there any other way to cut it? I have a circ saw, a recip saw, a jigsaw, and an oscillating multi-tool. Is there hope or am i SOL?
123pugsy 10-08-2013 09:17 AM
Anything that will cut it. A skillsaw, jigsaw, sharp knife, not so good,...etc.
You will need a router with a trimmer bit to take down the extra material that you leave when working with the laminate. It can not be cut exactly and then glued on.
TrailerParadise 10-08-2013 09:23 AM
I mean floating laminate... not glued. Just floating and covered at the edges with baseboard trim
123pugsy 10-08-2013 11:40 AM
Ha, and here I thought I actually knew the answer to your question....DUH....:huh:
I it were me I'd probably use a chop saw.
Oso954 10-08-2013 01:20 PM
A chop saw is definitely quicker, but it can be done with a circular saw.
If you use a speed square as a saw guide your cuts should be straighter. Marking and cutting from the back of the board will minimize chipping with the circular saw.
TrailerParadise 10-08-2013 02:40 PM
i can use a chopsaw, ive got one of those. Do i cut with the finished side up, or the back side up?
rossfingal 10-08-2013 02:51 PM
Cut with the finished side down -
Saw-blade with, as many teeth you can get (carbide).
TrailerParadise 10-08-2013 03:09 PM
thanks. my saw has a carbide blade but im not sure how many teeth. Guess i can give it a try and cut the first board a little longer than i need to see if it cuts smooth enough. Thanks for the help!
Oso954 10-08-2013 03:22 PM
Go buy the blade ! Something like this.
http://www.amazon.com/Irwin-Industri.../dp/B000089H9G
Cutting laminate is hard on sawblades. Consider it an expendable.
Canarywood1 10-08-2013 03:49 PM
" can use a chopsaw, ive got one of those. Do i cut with the finished side up, or the back side up? "
A miter saw,table saw,or radial arm saw,cut with face side up,only face down with a circular saw.
big juicy01 10-08-2013 08:52 PM
I always thought it didn't matter. If your cuts show up your not doing it right. X2 on the ruining of a blade lol
Davejss 10-09-2013 08:59 PM
I always use a jig saw. Its right there on the floor with me. No getting up and down a thousand times. All of your cuts are going to be hidden under molding so no need for a perfect cut. Also handy for notching and so forth.
