How To Do Step? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-24-2014, 01:34 PM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 1,976
How To Do Step?
This one has us stumped. Regretfully I don't think we thought this one through.
This the step from the family room into the laundry. We were originally thinking that we were going to use solid oak for the step since another step on adjacent side is leafs to the pub and that floor is going to be solid oak. And the reason for wood was so it would be easier to do the bullnose for the step.
Step is the easy part....but now we don't think wood is going to look good as the top step and transition to the tile. We are thinking that we need to use tile all the way on the top step. But how do we do the bullnose so that it matches the tile?
ddawg16 is online now   Reply With Quote
Old 05-24-2014, 09:02 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 576
If it were mine I would go with Oak or Birch tread with a wood landing tread with the nose extending out about 1/2 inch past any trim you put around the opening and return the nose back into the wall. If you get the landing tread wide enough you can bevel the back edge and rabbet it to overlay the tile.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Home theater riser, step - no step RegeSullivan General DIY Discussions 11 02-08-2014 08:07 AM
Can starting step tread be 3/4" deeper than other treads? hkeiner Carpentry 8 02-18-2013 10:24 PM
Hang drywall vertical or horizontal nickm1024cobra Drywall & Plaster 54 03-30-2011 11:37 AM
Unfinished step around wood laminate floors markq Flooring 7 07-17-2009 07:19 PM
tiling outdoor step kristinmcdonald Tiling, ceramics, marble 6 06-08-2009 11:02 PM
