How Do I Tell If I Have A Subfloor ? - Flooring - DIY Chatroom Home Improvement Forum
Old 07-19-2010, 11:09 PM   #1
How do I tell if I have a subfloor ?
How do I tell if I have a subfloor??
jrutledge is offline   Reply With Quote
Old 07-20-2010, 01:59 AM   #2
I can tell because my floor is also the ceiling in my basement. There's actually a couple of small gaps in between the planks where I can see straight through. Check it out from your basement or crawlspace.
LD004643578 is offline   Reply With Quote
Old 07-20-2010, 09:55 AM   #3
Tileguy
JazMan's Avatar
Rewards Points: 412
You have a subfloor if when walking on the floor you are still on top of the joists and didn't fall to the floor below.
What do you mean by that question?
Jaz
Old 07-20-2010, 10:51 AM   #4
Handyman
Rewards Points: 512
Jaz
Pull off one of the heating floor registers. That will show you what you have
canadaclub is offline   Reply With Quote
The Following User Says Thank You to canadaclub For This Useful Post:
DangerMouse (07-20-2010)
Old 07-20-2010, 11:11 AM   #5
the Musigician
DangerMouse's Avatar
That's the best way, yup! Thanks canadaclub!
DM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 06:29 AM
Replacing Subfloor whatispunk Flooring 1 09-01-2009 09:50 PM
Removing subfloor nickdu Flooring 3 07-28-2009 08:34 AM
Subfloor Help, Please! OmahaGirl Flooring 1 01-26-2009 08:06 AM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 07:39 AM
