How Do I Saw Out Very Edge Of Subfloor! - Flooring - DIY Chatroom Home Improvement Forum
Old 04-08-2006, 09:33 PM   #1
Construction Junkie
Red face
How do I saw out very edge of subfloor!
I've been pickin' at this damn thing all day, removed the bathroom floor to lay new tile and can't get out the last few inches (dontcha hate that?) because it goes under the cabinets (and it's under a toekick so I don't have any room). I'm trying to cut it out, pick it out, chisel it out, swear it out.... Bought a dandy reciprocating saw but it's just wayyy too much tool for me. This little bit has taken me longer than the entire tile job will. Any suggestions??
sharisavage is offline   Reply With Quote
Old 04-09-2006, 06:32 AM   #2
Oldguy
Rehabber's Avatar
Either remove the cabinet, or try a Fein multimaster. the Fein multimaster is a little expensive but very precise and very controllable. make sure you get a kit that has the saw blades with it
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 04-09-2006, 10:40 AM   #3
Construction Junkie
Thanks- I can see that removing the cabinet would be the best thing, but I'll destroy it if I do, and it's a custom shape so I don't want to replace it. I'll try the Fein.. If I can't get it perfect, can I butt the new plywood as best I can and fill in the gap with woodfiller before I lay down the cementboard? It's under the toekick so it's not going to have any weight on it...I'm usually a stickler for near-perfection but if I can compromise on this I'd like to.
By the way, you won't believe what the idiot in the tile dept at Home Depot told me yesterday...he insisted that I did not need to lay a subfloor over my wood joists, just the cement board. I can't believe that someone so clueless could get that job.
Old 04-09-2006, 10:52 AM   #4
Oldguy
Rehabber's Avatar
You can cut as close as you can and fill with SLC (self leveling cement) then install your backerboard per mfg's instructions.
Old 04-09-2006, 11:33 AM   #5
Don't know if the Fein will get under there either, you'll need a toekick saw and those are expensive and dangerous to use, I would just set my new subfloor up to that area, then fill the gap with modified thinset while tiling, you'll be fine.
R&D Tile is offline   Reply With Quote
Old 04-09-2006, 01:29 PM   #6
Construction Junkie
Thanks a million to both of you...I can't stand to have a job sitting around undone and now I'm confident I'll have tile on that floor by the end of the day. Bless you both.
Old 04-09-2006, 01:30 PM   #7
Construction Junkie
Modified thinset? Instead of mortar?
Old 04-09-2006, 01:53 PM   #8
Construction Junkie
then fill the gap with modified thinset while tiling, you'll be fine.[/quote]
My question should be, remember I'm using the filler before laying the cementboard, so is mortar or modified thinset better? And should I let it dry for a day instead of laying the cementboard immediately.
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 06:29 AM
subfloor question for hardwood installation metrokarl Flooring 2 05-16-2007 08:37 AM
BAthroom Subfloor Blaze25 Flooring 3 11-17-2006 09:06 AM
New Minnesota homeowner & found rotten bath subfloor...HELP! leahjane10 Flooring 72 11-15-2006 06:45 PM
COMPLETE subfloor removal alexschmidt Flooring 4 08-02-2005 11:15 PM
