How Do I Repair Cigarette Burns In Vinyl Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 11-25-2011, 05:37 PM   #1
How do I repair cigarette burns in vinyl flooring
I have a few small cigarette burns in vinyl flooring that is otherwise in good condition. Unfortunately it is in a high traffic area. I don't want to cut it out because I have no scraps to glue in there... is there any touch up paint or something... even if I have to touch it up every once in a while.
Thank you
h82diet is offline   Reply With Quote
Old 11-25-2011, 05:54 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 126
Sorry, patching is the only way. And a small patch in a high traffic area usually fails.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 11-25-2011, 05:59 PM   #3
Sniffle....
thanks for your reply. I'm think I may just drill out the burn (they're tiny and round, not elongated) and put some almond silicone caulk in there... or get a rug. Too bad... I was hoping there was a touch up paint like for chipped tubs.
Old 11-26-2011, 11:34 PM   #4
maybe drill them out and add a good epoxy try to match with a color close to the floor. or a nice floormat
busted is offline   Reply With Quote
Old 11-26-2011, 11:45 PM   #5
Rewards Points: 126
If you put a rug or floor mat on there make sure it doesn't have a plastic backing, or because of platicizer migration, you will have a bigger mess.
http://www.chemicalfabricsandfilm.co...lasticizer.pdf
Old 11-26-2011, 11:48 PM   #6
Rewards Points: 126
Even something like a plastic trash can sitting on a vinyl floor can cause staining.
Old 11-27-2011, 06:45 AM   #7
Chemistry!
Old 11-27-2011, 06:48 AM   #8
what type of epoxy to fill the holes?
I was in a restaurant bathroom recently and saw a seam down the the vinyl floor. It looked like it was filled with something hard and shiny. Is this the epoxy you're talking about? Where do I get this stuff? How is it applied? I only need about a teaspoon of it. Can I substitute something else?
Thank you!
Old 11-27-2011, 09:33 AM   #9
Rewards Points: 126
What you saw was a heat-welded seam. Has to be done by a pro. Takes some expensive equipment, too.
Old 11-27-2011, 12:56 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
We have all been in that restroom many many times and we know exactly what you are talking about. Rusty is correct, in that application it would be a welded seam. Not to be done DIY.
Old 11-27-2011, 02:13 PM   #11
RATS!!! These burns are small....1/8-1/4" round. If I drill them out, what can I fill them with that will stay put? They're bugging me because the floor is off white.
vinyl over vinyl flooring ri98 Flooring 3 11-08-2011 08:00 PM
Repair kitchen vinyl tile floor tomseeley Flooring 1 03-30-2010 11:26 AM
Vinyl siding repair sljacobs Building & Construction 5 02-28-2010 10:55 AM
Pulling up vinyl flooring, now what? loraxdh Flooring 9 10-24-2009 11:15 AM
Can I cover old cracked vinyl flooring with lauan and new vinyl? MikeC. Flooring 4 03-12-2007 05:20 AM
