How Do I Remove Purple Primer From White Linoleum Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-09-2012, 04:00 PM   #1
how do I remove purple primer from white linoleum floor?
how do I remove purple primer off a white linoleum floor?
amerigoplumbing is offline   Reply With Quote
Old 04-09-2012, 04:02 PM   #2
can u help me
Old 04-09-2012, 04:40 PM   #3
the Musigician
DangerMouse's Avatar
If you're CAREFUL, you could try (in a small area first) to use some clear pvc primer and see if that wipes it away. It'd be worth a couple bucks to see. It worked in a shower I cleaned up once.
Do a search here too, I seem to remember a thread about this.
DM
Old 04-09-2012, 08:02 PM   #4
DIY staff
Rewards Points: 7,174
That works if you can find clear---might need to call the plumbing supply shop for that--
Old 04-09-2012, 08:15 PM   #5
the Musigician
I got some at HD a few years ago. I'm sure all the BB stores will have it.
My only concern would be if it eats the finish off the lino before it dries?
(hence my suggestion to test it first)
DM
Old 04-09-2012, 08:22 PM   #6
Rewards Points: 13,270
Acitone on a rag will take it off.
How to remove paint from concrete floor? Jadams13 Flooring 6 12-23-2012 03:19 PM
How to remove old tile floor to prepare for new one Toocool100 Tiling, ceramics, marble 9 07-31-2011 06:19 PM
Quarter Round for hardwoods - White or match the floor? mr_ekco Flooring 6 02-22-2011 07:00 PM
Replacing rotten wood under linoleum bathroom floor tryingitourselves Flooring 1 08-21-2008 12:27 PM
How to remove white deposits on grout? digexpressions Flooring 6 05-12-2008 10:13 PM
