How Do I Remove This Ceramic Tile? - Flooring - DIY Chatroom Home Improvement Forum
Old 07-21-2007, 07:38 PM   #1
Rewards Points: 334
How do I remove this ceramic tile?
I have been trying everything under the sun trying to find a way to remove this ceramic tiling from my small bathroom floor.
Background: I have large ceramic tiling ON TOP of linoleum flooring. I have figured out the trick to removing the linoleum flooring (large scraper coupled with adhesive remover). But first I have to remove the ceramic tile first. I have tried everything: compressor with an air chisel,large crowbar with a hammer, and now I am using a wonder bar and a sledgehammer. But it is slow going. I am only knocking away the tile bit by bit (Now I know how Michelangelo felt). At this rate I should be finished in about a month.
Does anyone have any tips or tools or solvents that would help speed this up?
tripower is offline   Reply With Quote
Old 07-22-2007, 07:47 AM   #2
tiles
I feel your pain. I recently remodled our laundry room with 12x12 ceramic tiles.We bought a large lot of them so we could do the kitchen and bathroom as well. I got all the tiles mortared in and went to bed. The nex day i was going to grout only to find that nine of the tiles had a slight pink hue to them. Obviously a factory defect. I ended up buying a 3'' masons chisel> Yeah it sucked! Took me six hours to remove 9 tiles. 1/4 inch chunks at a time. Then I had to spread a layer of mortar around to fill the voids it created in the hardyboard.
rick32 is offline   Reply With Quote
Old 07-22-2007, 08:21 AM   #3
can you post a photo?
redline is offline   Reply With Quote
Old 07-22-2007, 11:30 AM   #4
Darylh's Avatar
I quite often break them up with a small sledge hammer amd then a wonder bar and hammer
Darylh is offline   Reply With Quote
Old 07-22-2007, 04:32 PM   #5
Rewards Points: 334
I think we are on the same page. How hard can I slam them with a sledge hammer before I have to start worrying about cracking by slab floor?
Old 07-23-2007, 10:45 PM   #6
Darylh's Avatar
I would not get to carried away, try hiting them on a angle with the sledge or start at the edges. Boy I bet you will be gladd when its all over
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 07:12 PM
stains on ceramic tile sdgoss Flooring 4 09-19-2008 07:19 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
Ceramic Tile Backsplash Installation DK75 General DIY Discussions 4 11-01-2006 08:56 PM
Ceramic tile installed over resiliant tile ramsfanjeff Flooring 1 11-26-2005 03:26 PM
