Old 05-08-2010, 09:55 PM   #1
DIY Expert in Training!
How do I prep subfloor?
So we demo'd my kitchen today. We had 6 layers of linoleum/luan!!! Anyway, we are down to the subfloor planks. Do I put 1/2" ply on top of this then cement board the tile? What do I put down before cement board?
Thanks!
gone_fishing is offline   Reply With Quote
Old 05-09-2010, 10:33 AM   #2
Tileguy
Bud Cline's Avatar
Minimum 3/8" exposure 1 underlayment grade plywood.
Cement board in fresh thinset.
Tile.
Old 05-09-2010, 10:37 AM   #3
the first house we purchased to live in was a civil war log hospital with a 2 story balloon framed addition the log part had 15 layers. you could tell which patterns they liked or got a deal on cause they repeated
The older I get the better I was
Old 05-11-2010, 08:17 PM   #4
Bud...right now we are 1/4" below the surrounding hard woods. If I understand your advice correctly I will put down 3/8" ply (Glue and screw) then 1/4" cement board. Tile will add another 1/4". This will put my kitchen floor 5/8" higher...I assume that's okay?
Second question...When I install the plywood do I want to go perpendicular to the joists and screw into the joists?
Thanks!
Old 05-11-2010, 08:59 PM   #5
Tileguy
JazMan's Avatar
Hi,
Bud's busy right now. (he may have gone fishing?)
3/8" underlayment grade is the minimum. NO GLUE. Fasten ONLY into subfloor planks, NOT the joists. So use screws that are 1/4" longer than the thickness of the two layers.
Tile will add a little more than 1/4" Hopefully the tiles a little thicker than that, plus the thin set. Figure 3/8" or so for the tiles. I recommend you use 1/2" underlayment plywood which measures a little less than 1/2".
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 05-11-2010, 09:04 PM   #6
And yes, it's going to be higher than your surrounding floor but that's what it takes to use tile. There are ways to transition the height difference.
Jim F is offline   Reply With Quote
Old 05-11-2010, 09:06 PM   #7
Jaz...thanks for the quick reply...1/4" or 1/2" cement board?
Old 05-11-2010, 09:53 PM   #8
Tileguy
JazMan's Avatar
Ditra.
It's more better....
Jaz
help with subfloor prep for ceramic tile johnpaul8379 Flooring 5 03-02-2010 02:26 PM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 07:29 AM
Subfloor Prep for Tile damnfloor Flooring 10 07-25-2009 04:57 PM
subfloor prep ? oscarMadison Flooring 2 03-27-2009 08:42 AM
subfloor prep farrington135 Flooring 1 08-15-2005 02:06 PM
