How Do I Place Marble Flooring When I Have Self Stick Tiles Right Now? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-23-2008, 05:24 PM   #1
Talking
How do I place marble flooring when I have self stick tiles right now?
Ok, my dilemma is that I have a very small bath room (64 in by 37 in) and someone gave me some beautiful marble tiles. I was wanting to use these tiles in this bathroom since it is a half bath and it is so small. Right now it just has the sticky self adhesive tiles which are coming apart and look horrible. How would i go about laying the marble flooring or can it even be done?
Jezka121102 is offline   Reply With Quote
Old 08-24-2008, 12:06 AM   #2
Tileguy
JazMan's Avatar
Rewards Points: 288
Hi Jezka,
First remove the vinyl along with any thin layers of plywood or similar panels. Once you get to the subfloor, re-screw it well and install another sheet of plywood, 3/8" min. thicker is of course better. Then install a tile backer board into fresh thinset and fasten per all directions. Finally install your tiles using thinset mortar.
Your subfloor system should be very stiff for marble and it's likely your standard joists system isn't. If you let us know the type and size of the joists. the spacing and the unsupported span, we can give you more info on what to do.
Jaz
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
underlayment for stick on tiles or vinyl novice40 Flooring 7 09-03-2008 05:49 PM
questions on self stick tiles NoExperience Flooring 6 08-20-2008 01:04 AM
Will vinyl tiles stick to this? rebekkah Flooring 1 01-12-2008 02:04 AM
