How Do I Install Hardwood Flooring To A Textured Wall - Flooring - DIY Chatroom Home Improvement Forum
Old 09-11-2010, 01:05 PM   #1
How do I install hardwood flooring to a textured wall
We are going to install hardwood flooring to a wall in our master bedroom, however, our walls are textured. Does this make a difference in the installation process, and what is the best way to install it (horizontally)?
cipstrip is offline   Reply With Quote
Old 09-15-2010, 10:50 AM   #2
Scrape off texture.
JohnJak is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
I want to install laminate plank flooring but have problem with sub floor In the Bush Flooring 3 04-29-2009 12:35 PM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 08:49 PM
Installing Help! hardwood flooring in Hot&Humid weather dvarga Flooring 7 08-08-2005 05:45 PM
