#1 |
How do I fix this gap in my floor?
I have tongue and grove oak flooring, and there is a 1/2" gap between two boards.
![]() The gap was 3/8", but I opened it up 1/8" to see if the board would slide. It does. One board (the one that slid) goes under a cabinet. I have pulled the molding and trim off the toe kick. ![]() My plan is to cut an opening in the toe kick, put a screw in the board under the cabinet, and pull on the screw to move the board forward to close the gap. I don't know anything about cabinets or floors, so while this makes sense to me, it might be idiotic. What do you think, will it work? Any other ideas? I have a couple extra pieces of the flooring, so I could cut a piece to go in the gap, but I don't think it will look very good. Better than the gap to be sure, but not as good as closing the gap. |
#2 |
How in the world did it get that way?
While what your suggested may work if there's no nails in the flooring for some strange reason, not sure how your going to get the screw in at a right angle to the flooring in a spot where it's not going to show once it's in place.
Please edit your profile so it shows your location! No one here knows exactly where on the planet you may be so how can we ansewer a code, building, or insulation question without it? |
#3 |
I bought it that way 9 months ago. I suppose it was just poor workmanhip.
I would be cutting open the toe kick so the screw and the new gap will be under the cabinet and won't be seen. The trim should hide the hole in the toe kick. |
#4 |
Somethings very wrong with that whole install.
There should be 0 gaps between the boards. No way should there ever be a 1/2 gap between those butt joint.
#5 |
Super Moderator
I've seen that before---you are on the right track----that board was not nailed.
Remove the toe kick---make a hook--- glue a small block of wood on the bottom of a longer piece--- then do the same on the top at the other end. When that's dry---use that to tap the section together---with some wood glue -- make sure it will move before adding any glue.
New members: Adding your location to your profile helps in many ways.--M-- |
#6 |
The installer probably did not realize that his nail gun ran out of clets. It looks like just one board is loose. All you have to do is put a large blob of liquid nail in the gap and pull them together with blue tape. Let them set for a few hours and it is fixed. Put plenty of glue in the joint but, don't put enough that it squeezes out. E-Z fix.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. I LOVE THE SMELL OF SAWDUST IN THE MORNING! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#7 |
Remodel and New Build GC
Just didn't get nailed.... then someone with "grippy" tennis shoes ran accross it and stopped .... dislodging
/sliding it under the cabinet. Can you try the same... like putting on grippy rubber soled shoes and sorta kicking on the surface in the direction to close it. That was prefinished flooring and should slide easily. Mike's edge puller will work great... but maybe you don't have to do that. To make it possible slide easier... put some talcom powder in its groves and jump lightly up and down. You can always set the board when you get it back in with a couple of face nailed finish nails and a spot of filler
Never stop learning (xcep fer speling en typeing) To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by MTN REMODEL LLC; 05-10-2013 at 09:20 PM. |
#8 |
It was easier than I expected. Gap is gone, wife it thrilled. Should have done it months ago.
I put some Captain Tolle's Crack Sealant on it. If you haven't tried Tolle's, it is a glue/caulk thinner than water. Wonderful for a situation like this. |
#9 | |
How do I fix this gap in my floor?Quote:
Never stop learning (xcep fer speling en typeing) To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#10 |
so you just "filled" the hole ?
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. i didn't make this world. i just live in it. be careful of whom you make fun of. one day, that could be you... |
#11 | |
| The Following User Says Thank You to MJ Force For This Useful Post: | MTN REMODEL LLC (05-12-2013) |
| Display Modes | |
| First Floor Laundry Room Floor Drain install? | hammerlane | Plumbing | 9 | 10-21-2011 10:12 AM |
| Dryer duct hole thru band joist & floor joist | justplumducky | General Discussion | 12 | 10-05-2010 01:31 PM |
| Split level walls and floor joists - how are they constructed? | jrbutterfly | Building & Construction | 2 | 06-09-2009 01:11 PM |
| 2nd floor air flow/pressure | fgillis | HVAC | 7 | 02-24-2009 05:58 AM |
| Levelling wood floor | gomi_otaku | Building & Construction | 13 | 11-27-2008 08:45 AM |
