How Do In Floor Heaters Work? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-05-2013, 03:19 PM   #1
Rewards Points: 180
how do in floor heaters work?
I'm thinking about using hot water in the floor for heating an area. I understand how it works except the part where the used water goes?
You take hot water from the water heater, run it thru the floor in tube to transfer heat, then where does the water go?
Do they use a separate pump and heat the water with a separate heater/heat transfer so it's a closed system separate from your regular hot water system?
KarlJay is offline   Reply With Quote
Old 01-05-2013, 03:26 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 120
It has a separate heater and the water recirculates.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 01-05-2013, 03:55 PM   #3
Rewards Points: 13,732
And not practical for just a small area.
It's great if it's new constrution and doing a whole house.
For small areas it's common to use electric mats instead.
grounding the workpiece you're welding jarnold Electrical 43 01-03-2016 07:14 PM
Contractor didn't start work in CT - What recourse do I have? ControlTech Off Topic 3 09-28-2010 01:45 AM
HVAC contractor ripoff! sekntonone HVAC 8 04-05-2008 07:15 AM
Need help with permit/city got a Stop Work Order. amdspitfire General DIY Discussions 39 02-07-2008 02:45 PM
Am I being overcharged for general construction work? baloney12 Building & Construction 2 07-11-2007 06:09 PM
