How Difficult Is It To Cut A Big (flange) Hole In Brittle Marble Tile? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-08-2013, 07:28 PM   #1
Rewards Points: 1,062
Question
How difficult is it to cut a big (flange) hole in brittle marble tile?
I am just asking this question here because, even though I will not be laying my tiles myself, my tile setter is currently overseas and inaccessible yet I am designing the floor tile pattern.
I am using 12" marble tile for the floor. My dilemma is whether to design the pattern so that I have two tiles with cut out semicircles meet around the flange or to have one whole tile with a full circle inside of it go all the way encircling the flange.
I would prefer to be able to do the latter (single tile with a large hole), however, given the material and size, I am not sure if that is possible. I think that the former is certainly possible but from the aesthetic perspective, I would like my pattern to involve one large tile around the flange.
I have heard that marble is really brittle and making fancy cuts is hard.
Old 04-08-2013, 07:50 PM   #2
Rewards Points: 528
Cutting it out of two is easier but one is possible.
framer52 is offline   Reply With Quote
The Following 2 Users Say Thank You to framer52 For This Useful Post:
amakarevic (04-08-2013), oh'mike (04-09-2013)
Old 04-08-2013, 07:56 PM   #3
Thanks. BONUS QUESTION: What tool can you use to make circular cuts in tile? Can you use a jigsaw with a special blade?
Old 04-08-2013, 08:15 PM   #4
Rewards Points: 258
This might work.
http://www.harborfreight.com/9-piece...kit-68116.html
Being human is the result of heredity.
Being humane is a matter of choice.
retired guy 60 is offline   Reply With Quote
Old 04-08-2013, 09:05 PM   #5
Rewards Points: 12,794
Got a picture of this flange. Without a picture were all just guessing what it is your trying to really do.
Old 04-08-2013, 09:10 PM   #6
really, a picture? how hard is it to visualize a circle on the floor? a perfect, round circle. no other variables involved.
it's not like one side of the circle is skewed. it's just a collection of points equally distanced from the center.
just .... a circle, Joe
Old 04-08-2013, 09:18 PM   #7
Ok, 1" circle, 2", 10" circle?
Guess your ok with a bunch of usless guesses.
Totaly differant tools needed for differant sized circles.
Old 04-08-2013, 09:30 PM   #8
r0ckstarr's Avatar
Rewards Points: 1,978
Got a picture of what you're trying to do?
r0ckstarr is online now   Reply With Quote
Old 04-08-2013, 11:19 PM   #9
Rewards Points: 322
I would use a diamond hole saw , but they get expensive the larger the hole.
tribe_fan is offline   Reply With Quote
Old 04-09-2013, 06:33 AM   #10
DIY staff
Rewards Points: 7,174
For the toilet hole---
A 4 1/2" angle grinder with a diamond blade is what most setters use---
Sometimes I'll set the tile into a flat pan with enough water to cover the tile--
Old 04-09-2013, 08:32 AM   #11
Do you pretty much just cut a square section out or can you get a circle shape with that?
oldhouseguy is offline   Reply With Quote
Old 04-09-2013, 09:07 AM   #12
Rewards Points: 258
amakarevic:
joecaption's question was better than my response. The size of the hole will certainly determine the method and tools needed for cutting your marble tile. I took the liberty of making an assumption as to what you want to do. Also, diamond hole saws are great for pros but for a one shot use a bit expensive.
oldhouseguy:
You can cut a circle with an angle grinder. It won't be perfect but any imperfection will be hidden by the toilet. Suggest you practice on a tile or portion of a tile you intend to discard.
Old 04-10-2013, 06:41 AM   #13
DIY staff
Retired guy is rift----no problem cutting a large circle with the diamond grinder----
Marble is very soft----the grinder will cut that easily.
Tags
marble tiles , tile
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 11:43 AM
Sealing Marble Tile - When to do it... usas12gthr Tiling, ceramics, marble 3 08-10-2011 10:37 PM
Can I tile on a shower flange? JakAHearts Kitchen & Bath Remodeling 7 08-30-2010 09:00 AM
Patch a hole in the bathroom tile sw41 Flooring 1 12-07-2008 01:57 PM
