-   -   How difficult is it to cut a big (flange) hole in brittle marble tile? (http://www.diychatroom.com/f5/how-difficult-cut-big-flange-hole-brittle-marble-tile-176622/)
amakarevic 04-08-2013 06:28 PM
I am just asking this question here because, even though I will not be laying my tiles myself, my tile setter is currently overseas and inaccessible yet I am designing the floor tile pattern.
I am using 12" marble tile for the floor. My dilemma is whether to design the pattern so that I have two tiles with cut out semicircles meet around the flange or to have one whole tile with a full circle inside of it go all the way encircling the flange.
I would prefer to be able to do the latter (single tile with a large hole), however, given the material and size, I am not sure if that is possible. I think that the former is certainly possible but from the aesthetic perspective, I would like my pattern to involve one large tile around the flange.
I have heard that marble is really brittle and making fancy cuts is hard.
framer52 04-08-2013 06:50 PM
Cutting it out of two is easier but one is possible.
amakarevic 04-08-2013 06:56 PM
Thanks. BONUS QUESTION: What tool can you use to make circular cuts in tile? Can you use a jigsaw with a special blade?
retired guy 60 04-08-2013 07:15 PM
This might work.
http://www.harborfreight.com/9-piece...kit-68116.html
joecaption 04-08-2013 08:05 PM
Got a picture of this flange. Without a picture were all just guessing what it is your trying to really do.
amakarevic 04-08-2013 08:10 PM
really, a picture? how hard is it to visualize a circle on the floor? a perfect, round circle. no other variables involved.
it's not like one side of the circle is skewed. it's just a collection of points equally distanced from the center.
just .... a circle, Joe
joecaption 04-08-2013 08:18 PM
Ok, 1" circle, 2", 10" circle?
Guess your ok with a bunch of usless guesses.
Totaly differant tools needed for differant sized circles.
r0ckstarr 04-08-2013 08:30 PM
Got a picture of what you're trying to do?
tribe_fan 04-08-2013 10:19 PM
I would use a diamond hole saw , but they get expensive the larger the hole.
oh'mike 04-09-2013 05:33 AM
For the toilet hole---
A 4 1/2" angle grinder with a diamond blade is what most setters use---
Sometimes I'll set the tile into a flat pan with enough water to cover the tile--
oldhouseguy 04-09-2013 07:32 AM
Do you pretty much just cut a square section out or can you get a circle shape with that?
retired guy 60 04-09-2013 08:07 AM
amakarevic:
joecaption's question was better than my response. The size of the hole will certainly determine the method and tools needed for cutting your marble tile. I took the liberty of making an assumption as to what you want to do. Also, diamond hole saws are great for pros but for a one shot use a bit expensive.
oldhouseguy:
You can cut a circle with an angle grinder. It won't be perfect but any imperfection will be hidden by the toilet. Suggest you practice on a tile or portion of a tile you intend to discard.
oh'mike 04-10-2013 05:41 AM
Retired guy is rift----no problem cutting a large circle with the diamond grinder----
Marble is very soft----the grinder will cut that easily.
