How To Cut Floor Around Post? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-25-2014, 12:03 AM   #1
listo's Avatar
Rewards Points: 95
How to cut floor around post?
Is there a better way to install laminate around a post?
I could have used the piece I cut out but there was more space from my saw blade than I was happy with. Stupid post had to end up right in the middle of my board. I also could have made another cut a little straighter i suppose but it was my 4th attempt and I was getting pissy.
The other two posts in the basement ended up in a joint so I was much happier with them. Here's one
listo is offline   Reply With Quote
Old 05-25-2014, 12:09 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I would have cross-cut the flooring at the center of the post. Then cut a (well layed out) half-circle in each flooring piece. This would then allow for a single seam on either side of the post that could be closed tightly leaving only a hairline crack to caulk on both sides of the post. Not near as noticeable. A much better cut could have been made around all of the posts.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
BigJim (05-25-2014)
Old 05-25-2014, 12:17 AM   #3
listo's Avatar
Rewards Points: 95
Thanks bud that's nice of you, I was proud of that other one, now not so much
Old 05-25-2014, 07:07 AM   #4
DIY staff
Rewards Points: 7,174
Next time--start the row at the post so that each board has a half round cut ---and a factory seam in the center of the post---Clear as mud--right?
kwikfishron (06-01-2014)
Old 06-01-2014, 05:59 PM   #5
Rewards Points: 1,476
Box out the pole into a column. What were you going to do with the poles?
mikegp is online now   Reply With Quote
The Following User Says Thank You to mikegp For This Useful Post:
listo (06-01-2014)
Old 06-01-2014, 09:49 PM   #6
listo's Avatar
Rewards Points: 95
That was my plan in the endgame anyway, they were gonna be columned
Old 06-01-2014, 10:19 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
NOW you tell us !!!
I'm not sure I'm buyin" that story.
XXX
Old 06-01-2014, 10:28 PM   #8
listo's Avatar
Rewards Points: 95
Lol I never asked how to make it look better, I was asking if there was a better way for next time, hopefully there won't be a next time though
Reuse Concrete Fence Post Pier & Fence Post Extraction JasonCA Landscaping & Lawn Care 2 03-24-2012 08:58 PM
New posts and beams in crawlspace, post out of line WillK Building & Construction 1 02-26-2012 09:56 AM
Tiling vertical post kellyharris15 Flooring 12 02-22-2011 03:28 PM
Deck Post Height for Composite Post Railing ylwdog Building & Construction 5 11-15-2010 09:01 AM
