How To Cut Exhisting Flooring In The Doorway - Flooring - DIY Chatroom Home Improvement Forum
Old 01-20-2008, 12:09 PM   #1
How to cut exhisting flooring in the doorway
My master bedroom has hardwood flooring that runs thru a doorway and continues into a dressing room with no threshold separating the two. I am using this dressing room area for a bathroom remodel thus doubling the bathroom size. I have to remove the wood flooring that is in the dressing room in order to lay the new bathroom tile. I need advice on cutting the wood flooring in the doorway(between bedroom and dressing room) so that I can transition the new tile and wood flooring in the bedroom. To be clear, the wood flooring runs perpendicular to and thru the doorway walls and the boards are of random length. Any and all suggestions appreciated.
jjpar is offline   Reply With Quote
Old 01-20-2008, 12:13 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Fein Multimaster: http://www.feinus.com/
- Build Well -
Old 02-22-2008, 09:17 PM   #3
I am dealing with the exact same situation. I have hardwood running perpendicular through a doorway connecting a foyer and powder room. I am remodeling the powder room and I want to put tile on the floor. I've only solved part of the problem so far (the easy part!). First, I cut a spare piece of hardwood to the width of the threshold and wedged it in to use it as a straightedge. Second, I adjusted the cutting depth of the blade on a circular saw to equal the depth of two hardwood planks. Then, I set the blade against the straightedge and cut across the threshold as close to the edges of the doorway as the saw would allow. What I am dealing with now is the 2 to 3 boards on either side of the doorway that the circular saw could not cut. I've tried several things to little avail. I will next try a chisel. If you have solved this problem, I would love to hear from you!
kkase is offline   Reply With Quote
Old 02-22-2008, 11:01 PM   #4
Reply to Thread
I solved the problem easily, but it was an expensive solution. I cut a piece of wood, laid it jamb to jamb in the doorway as a guide, then cut the flooring with a Fein Multimaster using their "E" blade. The tool cost me about $300 with shipping, but it provided a smooth cut. I had originally planned to sell the tool on ebay, once I complete the project, but liked it so much that I'm keeping it for other projects. Sorry that I can't offer a low cost solution. If you will be installing a piece of threshold then maybe , with lots of labor, a pull saw could be used to finish the cuts. Good luck to you, James
Old 02-23-2008, 08:21 PM   #5
Thanks James. I saw the post on that tool and I was tempted. I managed to get the rest of the hardwood out this evening, but mostly by brute force. Before forcing it, I used a small bit and drilled holes very close together along where I wanted the cut line to be to perforate the planks. That seemed to do the trick, but it was neither fast nor easy. I might have to look into a Fein Multimaster for future projects! Kate
Old 02-23-2008, 09:50 PM   #6
Crabby Bastard
terri_and_jj's Avatar
for $10 - $15 you can get a tool made just for this, called a floor chisel. a few whacks with a hammer and you are all set. There is a company call Hard Cap that makes one with a big red safety cap, cost a few dollars more, but your hands will thank you later!
terri_and_jj is offline   Reply With Quote
Old 03-06-2008, 08:04 PM   #7
Rewards Points: 264
heres what i do
use a biscuit joiner and straightedge to cut into the flooring where the repair is needed. finish off cut with a chisel. works great! fast and cheap!
What have I done is offline   Reply With Quote
Old 10-25-2011, 05:11 PM   #8
HFT Is The Bomb!
I bought a Harbor Freight tool that does the same thing Fein's does, looks a lot like it, too. According to the HFT flyer I have they are $39.99 with their coupon. Believe me, you can't go wrong with HFT, regardless what the boneheads say about them. If you don't like your purchase - get a refund. Simple as that. I really find it hard to believe, a tool that does basically the same thing, costs over $75.
tediam is offline   Reply With Quote
Old 10-26-2011, 12:01 PM   #9
Sephora's Avatar
Rewards Points: 150
Just picked up the Bosch MutiTool for $159...still pricey but I wonder if it will outlast your HFT.
Sephora is offline   Reply With Quote
Bathroom Flooring? Whole House Flooring? leezarrd Flooring 9 02-08-2012 02:47 PM
Engineered Flooring Doorway Transitions? GaryD Flooring 1 12-21-2007 06:06 PM
Gameroom basement flooring? PaulMcC Remodeling 4 03-09-2006 10:08 AM
