Thanks for the detail reply... I would do laminate on one more layer of treads then... Manufacturer requires gluing them rather than floating them on stairs... they do have parts the for the nose you are talking about, but I think I won't use them because of not strong enough I feel, I probably screw in regular metal nose after laminating... I might as well laminate the risers as well rather than painting as recommend by you....
I think I made the mistakes myself causing me need to lay an extra layer of treads, builder orginally built the stairs with treads, I added the risers myself, but I probably added it wrong by putting the risters on top of the treads below it rather than move it a bit behind and nailing them to the treads below it... didn't think of that and now cause me requires to add all these treads ... I never think of this thing so tricky.... I didn't know the treads need to exceed a little bit in order to walk on it compfortably, I was thinking making a perfect 90 degree angle is nice and clean and good support... obviously, this is wrong... well unless someone outthere tell me I didn't do it wrong... which makes me feel a bit better....
