How To Cover A Hole In A Floor Slab - Flooring - DIY Chatroom Home Improvement Forum
Old 11-16-2009, 11:59 AM   #1
Rewards Points: 41
How to cover a hole in a floor slab
The "genius" I bought my house from remodeled his outdoor carport and poured a concrete floor over it, to turn the carport into an interior room, and in the process he poured that slab right over the access to his septic tank!
So now I have to bash a hole in the slab to pump out the tank, and I want to replace the hole I'll make with something that is removable the next time I or a new buyer has to pump out the tank again!
I need to create a 32" square opening in the concrete slab that forms the floor of my interior home office. I'm considering a range of options for making a removable hatch that I could set down into the opening on a frame of some sort that would be anchored to the insides of the opening.
I figured out the slab I'd cut (assuming I can cut out the existing floor at all, which is a different subject) would weigh so much that reusing that would be impractical. No one could easily lift it out of the opening.
I'm considering a steel or aluminum plate about 1/4" thick, supported on some sort of metal frame anchored to the insides of the opening. Would a steel or aluminum plate 1/4" thick, and 32" square have the necessary load bearing capacity to become part of a normal room floor? I assume yes, but I'm not a structural engineer. How heavy would a piece of "vanilla" carbon steel plate 1/4" thick and 32" square weigh, anyway?
I'm also considering just using 2x4s for the frame around the insides of the opening, and putting a piece of 3/4" plywood on it, to form the removable hatch. Perhaps I'd put some 2x4s under the plywood to give it some stability in the center of the 32" span in each direction. Would THIS have the necessary load bearing capacity?
What else can anyone suggest? Or can anyone think of problems with whatever I'm considering?
tomseeley is offline   Reply With Quote
Old 11-16-2009, 12:56 PM   #2
Remodeling Contractor
you can buy a round cover and extension ring that is made for this. It will extend the opening and provide a finished cover. Or leave out the cover and make one with the finished floor material. You can then pour cement around the concrete extension ring to finish off the flooring.
Old 11-16-2009, 01:14 PM   #3
ArmchairDIY's Avatar
Thats not a good situation, but I don't need to tell you that I guess.
Is it possible part of the tank is outside? Could you create a new access hole outside the building?
Wow, thats a screwy deal. I also wonder if you need to fabricate some type of gasket system for the tank cover so you do not end up with sewer gas in the house if you do keep the cover location were it is.
"It looked good on paper, but paper is funny that way"
Time to Get Up Out of Your Chair and Do it Yourself! ArmchairDIY.com
ArmchairDIY is offline   Reply With Quote
Can I cover this hole with insulation? [pics] Brandon19 HVAC 5 10-08-2009 10:47 PM
What to cover the toilet drain hole with while doing renovations? RyanD Plumbing 4 06-15-2009 07:05 AM
Install manholes (access) hole in concrete septic tank cover rkpatt General DIY Discussions 2 02-23-2009 07:37 PM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 11:28 AM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 08:34 PM
