Old 09-01-2012, 06:24 PM   #1
How to correct an uneven concrete pour before installing laminate floors?
We are putting down laminate floors and after trying to level parts of the concrete were there was. A recessed ridge we may have made the concrete too thick and there is a slight mound that is not level- any suggsuggestions on how we might sand it down?
F.O Wills is offline   Reply With Quote
Old 09-01-2012, 06:26 PM   #2
Super Moderator
An angle grinder with a diamond grinding cup should make short work of that----
Old 09-02-2012, 10:38 AM   #3
you ARE NOT looking for "level". you ARE looking for "flat" .
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Installing Laminate Flooring over Wood Laminate Floor bantammom Flooring 7 05-27-2011 04:34 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 02:56 PM
Laminate Floors over radiant heat in concrete slab richnsht Flooring 8 05-23-2009 01:16 PM
Buckling of Laminate floors branjack Flooring 13 12-26-2007 01:38 PM
