How To Clean Very Dirty Travertine Floors? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-23-2013, 11:48 PM   #1
Rewards Points: 145
how to clean very dirty travertine floors?
Is there a chemical solution to use, whats the best way to apply it?
thx
wantboost is offline   Reply With Quote
Old 02-24-2013, 04:38 AM   #2
DIY staff
Rewards Points: 7,174
-----Travertine is one of the softest , most absorbent of the marbles---hot soapy water and a scrub brush is about the best you can get without dissolving the stone----
Do not use any acid based cleaners---they will dessolve the stone---
I have actually sanded the surface with a random orbit sander----
Old 02-25-2013, 10:22 AM   #3
Rewards Points: 145
dish soap?
Old 02-27-2013, 08:46 PM   #4
DIY staff
Dish soap and a scrub brush will be safe----also a call to Aqua Mix might be worth while---they are the maker of many good marble products---
Old 05-19-2013, 09:29 PM   #5
Rewards Points: 145
what harm will a acidic cleaner do to the floors?
Old 05-20-2013, 05:38 AM   #6
DIY staff
The travertine will dissolve--
Marble is a lime based stone----acid will destroy the surface---softening it and causing lots of damage.
Old 05-20-2013, 07:26 AM   #7
Hi, I am not sure about the chemicals, but you can make use of water simply to wash the dirty floors.body, div, table, thead, tbody, tfoot, tr, th, td, p { font-family: "Arial"; font-size: x-small; }
Albert123 is offline   Reply With Quote
Old 05-26-2013, 12:25 AM   #8
The most important thing you need to know about cleaning travertine is not to use strong chemicals.
Acidic and even akaline chemicals will etch the travertine. Vinegar is acidic and bleach is akaline, so you do not want to clean travertine with either one of these cleaners.
Neutral cleaners for natural stone are recommended and available at tile stores and if you don't have a neatral cleaner, use warm water to clean you travertine surface.
When cleaning your travertine floors, mop the travertine tiles with your neutral cleaning solution or warm water.
katyhome is offline   Reply With Quote
Old 05-27-2013, 12:49 AM   #9
Aluminium Security Doors
Travertine tile cleaning must be done at a deeper level at least once a year for a normal household.
Old 05-27-2013, 12:56 AM   #10
Rewards Points: 6,652
thx
Sudsy Ammonia and some elbow grease. Nothing better and cheaper than special cleaners that tile places will state work better than the other company. Just beware that using Ammonia to clean the floor, that if you do not rinse it completely off the tile and grout, the salts in it will bleach the grout color. You can get grout stain to restain the grout back to the original color, but tiles like Travertine tend to soak the stain into it, so you really have to be cautious.
Old 05-28-2013, 02:15 AM   #11
Yes, Many Chemical are available in the Market to clean Dirty Travertine Floor
but i want to give advice not to use strong chemical otherwise it is harmful for Floor.
Hi. Newbie with sagging floors Erika Conn Flooring 2 03-08-2012 03:17 AM
Air Filters - One Dirty, One Clean Neal_Texas HVAC 9 01-16-2012 05:21 PM
Cleaning travertine floors millelacs Flooring 2 06-19-2010 08:01 AM
Resurfacing Wood floors roxksears Building & Construction 2 10-23-2009 08:50 AM
Washing my wood floors J187 Flooring 1 11-14-2006 10:13 PM
