How To Clean Between The Hardwood Cracks - Flooring - DIY Chatroom Home Improvement Forum
Old 07-24-2013, 09:19 AM   #1
How to clean between the hardwood cracks
I have hardwood floors, and between two running lengths, a big enough divide has split between them. Allowing dirt and stuff to gather up.
How should I clean it up without damaging the hardwood and what should I use to fill in that split to prevent anymore buildup?
Thank you!
MangoMelon is offline   Reply With Quote
Old 07-24-2013, 10:28 AM   #2
Rewards Points: 14,312
Got a picture.
A Shop Vac will suck it out.
Any type of filler is going to stick out like a sore thumb.
Old 07-24-2013, 01:21 PM   #3
Rewards Points: 274
Take a small brush and try to clean out the dirt with that.
alexjoe is offline   Reply With Quote
Old 07-24-2013, 07:12 PM   #4
here's a pic
Leveling hardwood for laminate Fred_ Flooring 3 03-23-2013 11:22 AM
Lay New Hardwood On Hold Hardwood TJfive0 Flooring 3 04-30-2011 05:50 PM
Repair on Concrete Drive Way Cracks jamiedolan Building & Construction 4 08-17-2010 11:40 AM
Foundation cracks drain tile fiveoh018 Plumbing 3 06-26-2010 02:55 PM
Advice needed for filling large basement Cracks dgbehrends Building & Construction 11 11-17-2009 04:23 AM
