How To Check A Floor For Flatness - Flooring - DIY Chatroom Home Improvement Forum
Old 01-03-2011, 09:23 PM   #1
Rewards Points: 370
How to check a floor for flatness
Just wondering if there are any easy ways to check a floor to see if it's level enough for a tiling job (12x24's) I've seen a bunch of places talking about how important it is, but I haven't seen any places describing a way to check. I'm hoping there's some trick to using a laser level or something.
Thanks for the help.
MLMIB is offline   Reply With Quote
Old 01-03-2011, 09:27 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 52
Flat and level are different things.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 01-03-2011, 09:50 PM   #3
Rewards Points: 558
The easy way is to measure the room and find the center point of the room and mark it with an X using masking tape. From this spot mark each quadrant into four squares, locate the centers and mark with an X. This will allow you to see changes in the floor throughout the room.
Now place the laser level in the middle of the room and level it. Shoot the laser on each wall and mark that spot with the pencil. This gives you a defined spot. Then move the level to each one of the other Xs and level it. Shoot the laser onto the wall. Mark that spot. Make sure this is done at 90 degree angles. You do not want to go onto the other marks.
When all walls are marked and you went to each quadrant you can now measure each pencil mark. This will allow you to see where each section of the floor is resting. It also tells you if you have settling issues. If you have areas that are more than an inch above or below another area, you will need to contact a contractor because there may be a problem with your foundation.
epson is offline   Reply With Quote
Old 01-03-2011, 10:16 PM   #4
Civil Engineer
Rewards Points: 4,568
There are two relatively fast, simple ways to measure a floor for LEVEL (not flat). The techniques depend on what equipment you have.
If you have a rotating laser level (I got one for less than $75 at a big box store), you set the level up in the middle of the room, and proceed to walk around the room with a tape or a graduated rod and make measurements. This will give you a direct way to measure how far out of level any given spot on the floor is. If you do not have a rotating level, you can use a standard builders level on a tripod with a rotating head to get the same result.
If you have a fluid level, or rent one, you can directly measure the elevation of any given spot in the room. Simply walk around, make the measurements, and plot them on a piece of graph paper.
Note that both of these techniques will tell you how far out of level a given spot is. The floor can be uniformly tilted (i.e. perfectly flat), but still be out of level, and these techniques would show an out of level floor (true), but without some math would not show that the floor was flat.
Old 01-03-2011, 10:48 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 290
It's important and good to know, but the tiles don't care if the floor is level or not. It only cares that it's flat.
Take a long straight edge and lay it on the floor in many areas. You will easily see if the floor has humps or valleys, usually both.
With 12x24" you want the floor to be within 1/8" in 10 ft. & 1/16" in 12" of plane.
Jaz
Old 01-03-2011, 11:52 PM   #6
Rewards Points: 200
Go to Harbor freight and pick up a 6' level for $20.00
Flatness guidelines are 1/8" in 6' or 3/16" in 10'.
Or you can duct tape a 10' string to the floor , pull it tight , tape . it will also show you the contour of the floor .
move one end in a circle every 1' .
Floor Doc is offline   Reply With Quote
Loud sump check valve BlueBSH Plumbing 1 01-19-2010 05:14 PM
Check whether metal grounded or not televisi Electrical 2 11-18-2009 11:00 PM
Leaking double check valve assembly (Watts) secutanudu Plumbing 0 06-07-2009 07:52 AM
check my wire diagram please. thanks! fabian Electrical 8 01-04-2009 12:32 PM
Lockout - check furnace. newbie102 HVAC 2 07-10-2006 07:50 PM
